My C4 had on the underside of the console lid a label with a bunch of spec info on it - is this on the C6 somewhere too? If not how can I get the list of the specs/options, etc.
Blueboy, you can pop open the glove box and look for the option codes, or, you can go to any GM dealer with your vin and ask the service department to print the VIS and build sheet for your car. Free.
Amazing what it will tell you.
RPO Codes. That's what you are looking for. side of glove box, silver label.
This site: https://www.corvsport.com/2008-c6-corvette/ has loads of information on specific years, so you can pick your year (2008 is linked here) and sort through the options codes that appear on your label.
((edit))
Specifically, look at posts #16 and #17 in that thread. it might help. Especially the bit about the GM hologram making the codes near invisible in the wrong light. However, if your sticker is missing, then you might need to go a different route. Like what ruxvette mentioned.
Blu Dice here - dealer gave me the "build sheet" data - thank you very MUCH - I have a Z51!!
But they looked blank when I asked for the VIS - so what is this??
A VIS (I'm not sure it's still called that) is a report of all repairs done to the car at a GM dealer. It also shows whether it has a warranty block or branded title.
Many people miss it the first time. It's on the inside of the glove box door, extreme left side, almost all the way down to the bottom edge of the door. Take a flash light with you. It's there.
