Vibration
Old Jun 9, 2018 | 04:41 PM
Chapi's Avatar
Chapi
Cruising
Default Vibration
Okay so here's the deal I went had four tires balanced on my 2005 z51 and continues to have a pulsing vibration minor at 90 they use those flat sticky weights not sure if one fell off but I'm going to have all four rebalanced and if that's not the problem what could it be. Anyone? Thank you
Old Jun 9, 2018 | 05:01 PM
car2fast4you's Avatar
car2fast4you
Having the tires road force balanced is an absolute must on a Corvette. They may need to remove the tires & rotate them on the rim to get them properly balanced.
Old Jun 9, 2018 | 05:26 PM
Lee Cromwell's Avatar
Lee Cromwell
Agreed!!
Old Jun 9, 2018 | 05:33 PM
Chapi's Avatar
Chapi
Cruising
Default Vibration
Hey car2fast is that an atomic orange c6? 😎 so I'm a little lost as to how to road balance a tire. They remove the tire then balance the wheel ?
Old Jun 9, 2018 | 05:37 PM
Chapi's Avatar
Chapi
Cruising
All good. Goggled it i will be finding a shop for this asap. Thank you for the help
Old Jun 9, 2018 | 07:04 PM
449er's Avatar
449er
CF Community Team
Road force balance
Old Jun 9, 2018 | 07:10 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
How old are the tires? A minor vibration at 90 mph might not be fixable.
Old Jun 9, 2018 | 07:25 PM
Chapi's Avatar
Chapi
Cruising
I bought the car in Feb and here in maine, haven't had a chance to take it up to the speeds of the vibration till now on the pike. The fronts have 9/32 left...90% and rears have 6/32 but the rears seem to be a little more warn in the middle vs outsides.
Old Jun 9, 2018 | 07:28 PM
Chapi's Avatar
Chapi
Cruising
Car has 50k so im assuming this is the 2nd pair of shoes
Old Jun 9, 2018 | 07:32 PM
919cw313's Avatar
919cw313
Hmm. I don't know how much I'd invest in working on tires I don't know the history of, for a minor vibration. There's more to tires than just tread depth.
Old Jun 9, 2018 | 07:48 PM
Chapi's Avatar
Chapi
Cruising
And....it drives flawlessly 85 and under and is even less noticable at 100. Don't think ill be doing 90 very much anyhow lol. Sounds like your saying go till I need new rubber which sounds like a plan.
Old Jun 9, 2018 | 08:09 PM
919cw313's Avatar
919cw313
^ That's the way I'd lean. I really think you're going to lose a $100 (+/-) gamble on road force balancing, but there's only one way to find out.
Old Jun 10, 2018 | 12:01 AM
Oh Boy's Avatar
Oh Boy
A couple of other things to consider. Make sure your mating surfaces are clean (rim to rotor), if you do a roadforce balance make sure the numbers are under 10, preferably under 5 and make sure your lug nuts are tightened to 100 ft/lbs. Any tighter and you might get a vibration, it has happened to me.
Old Jun 10, 2018 | 09:34 AM
Chapi's Avatar
Chapi
Cruising
I have brand new rotors/ pads all around an I'm torqued to 100
To Vibration
