Door panel pin hole(grommet?) part number?
I removed my passenger side door panel due to a rattle around the speaker location. On removal I found 2 different style door pins on my door(never looks to have been off, but??). The 2 that are different go into holes in the door frame that do not have the white plastic grommet piece the other pins go through. Is there a part number for that grommet? I found the pin part number.
Race Car Tech
part # 10350983
GM Trim Panel Grommets With Sealer Corvette
part # 10351052
They can be found at most auto parts stores, or GM parts counter, or at clipsandfasteners.com, or e-bay.
The following 4 users liked this post by 4SUMERZ:
I ordered 10 of them. I lost 3 in the passenger door. I'll see how the new ones set in there, but it looks like the paint around the holes is damaged...Maybe the grommet pulled a little too much as it came out. Thinking I might have to put a dab of epoxy or similar on the edges as the new ones go in, if loose.
