NPP Leak Cause Lean Codes?
Side note I am having my tuner look at the tune next week. I am certain he can fix it. I do not think I have a vacuum leak as the car idles great.
Note, if you car did not come with NPP, then should still have the wings section on the port with the port still sealed off. Once you crack the wig section off to install the NPP line, then delete the NPP system, then you need to rubber port cap the port off instead.
That said, there is too little to go on here without more details. Specifically, when did the lean codes show? After what event(s)? Also, were the mods and tune done in that order? Or, did you possibly do one of the mods after the tune?
If you really know the manifold port was open and the lean codes came up then, it is pretty good info, that is your problem. Assuming your tune is good, I've seen (and heard about) tuners out there who really don't know how to properly tune headers especially, and with the addition of a CAI. Some simply disable sensors or increase tune tolerances so they don't produce CELs, but they don't know how to set O2 sensor delays to accommodate for the new locations in the headers. That can screw up fueling BC the ECM doesn't know the O2 sensor data coming in is so far delayed from the real combustion event.
Back to the CAI, without knowing the brand, type, etc.; there is a possibility turbulence around the MAF is causing the MAF frequencies to be disrupted. The ECM relies on correct air volume at any given RPM to correctly meter fuel. If, lets say, air turbulence around the MAF at some RPM range causes an incorrectly low frequency, then the ECM will fuel to it, but in reality, there is far more air than is being measured. BUT, a good tuner will know this.
Last thing, if you think you have it now with the intake port plugged, fuel trims will eventually correct themselves and should get back to a normal range IF the tuner set up fueling that way in the first place. Assuming he did, LTFTs move pretty slowly and will take a little driving to correct. But, if you want to accelerate it, and have the capability to erase codes, delete them, then disconnect the battery. Leave disconnected for several minutes to be sure, but doing that will cause LTFTs to be lost, so when you restart, the ECM will begin building new FTs based on the current conditions. If you do that and get 171/174 again after some driving then, you haven't yet arrived at the lean issue.
If it takes a week of driving to produce the lean codes, they're not caused by a manifold vacuum leak like a port open. You have a tune problem.
BTW, if you haven't heard, the heads may give you $$$$$ problems. Keep a close eye or ear on it.
