Shift to reverse
Old Jun 21, 2018 | 08:41 AM
kvnjames's Avatar
kvnjames
1st Gear
Default Shift to reverse
DIC says shift to reverse,,, its in reverse end it still doesn’t shut the power off,, any suggestions please ?? Thank you !!
Old Jun 21, 2018 | 09:01 AM
JasonAndrew's Avatar
JasonAndrew
It actually may be in 5th, try again for reverse.
Old Jun 21, 2018 | 09:05 AM
PCK1221's Avatar
PCK1221
I think i've read that there is a switch that goes bad.. you'll have to do a search for it
Old Jun 21, 2018 | 11:01 AM
RicK T's Avatar
RicK T
It is "probably" the switch located on the trans. The '05 (only) M6 has two (2) switches on the side of the trans case, one for the reverse lights, the other for the computer to shut down. I'm pretty sure they are the same switch. If you want to just throw parts at it hoping it's the switch I suggest you replace both at the same time.
Look at post 2 in here, pics and a good description:
https://www.corvetteforum.com/forums...hat-to-do.html
To Shift to reverse
