Any change with oem emission equipment is against Federal Law.
Air cleaner and anything back from the mufflers.
I'm not sure it's that cut and dried.
My buddy has an '09 Shelby Mustang, tune and headers. He could not get it inspected here in NYS, so he registered it in Florida where he is for 7 months out of the year. Seems to me they don't even have inspections in FL but either way, he had no problems getting it registered and legal.
Maybe the Florida guys could chime in here and fill in the blanks.
I live in St Louis. If I put longtube headers on a ls3 would it pass emissions ?
What does your state say about that? There is no nation-wide ban on LT headers. Here in NV, we can run LT legally, and if the system checks out, we are good to go. In CA, you cannot even change out a muffler. So, check your state emission requirements.
BS - As far as Federal is concerned you can make any changes you want as long as your vehicle meets federal emission standards after the changes have been made.
This ^^^. Some states allow changes as long as the emission standards are met, others, like CA, don't allow any changes even if your vehicle meets the standards … my brother found this out the hard way. Additional, some states/counties don't have inspections or ha exemptions; for example Clark county in Nevada requires inspections, but the City of Mesquite, where I live, is exempt and we don't have any inspections.
St. Louis area emissions checks are currently OBD-II checks only. As long as you don't have any codes due to the rear O2 sensors being too cold, since they are further downstream, you will pass. Any decent tuner can also tune out the OBD-related rear O2 sensor codes so they are not reported, and you can also pass emissions that way with long tube headers.
Like others have said, it depends on your state and county. "Tampering" with federal emissions is illegal, however some states do not have inspections, so no one knows. Other states have inspections and must comply. Then, there are counties within states with inspections that are exempt from bi-annual inspections, until you sell the vehicle. Research the laws in your state and county before modifying any emissions components.
Emission requirements change, so don't assume what was true 5 years ago is true today.
Technically, relocating the catalytic converter downstream is "tampering" because the further you move the cats away from the exhaust manifold (LT's) the less efficient it becomes.
Of course one can replace a faulty component with a like part. In California we are very strict.
Still it is against Federal law to remove and leave off any emission part and run the vehicle on the road.
You have changed the wording of your original statement. In any case, I know it is unlikely, but can you post the actual reference to that law? I believe it reads quite different, but cannot verify either way. Thanks.
California isn't quite that bad. Change from cats back is no problem. I installed Corsa Sport axel back and it passed smog. West Coast Corvette is in Anaheim. They sell and install lots of axel back systems.
Batman is correct....Cats back is okay to change out (mufflers). You can't even change to a CAI unless it has a CARB EO number. I added a RIPP supercharger to my Jeep, it has a CARB EO number and passed smog inspections just fine, so some things can be added it just needs to go through that approval process.
Long tubes are a no go in Ca. though...unless its pre-1975 then you can pretty much do whatever you want...
There are a few counties in the state of Ca. that don't even require smog unless the vehicle changes ownership so that's another option in Ca.
There is no Federal law saying you cannot change you're OEM emission system or parts thereof; Federal law requires you meet the standards (i.e. you pass emission tests). The Federal government has left it up to individual states to implement the minimum standards or, like California and other CARB states, to implement even stricter requirements.
I knew that, Buddy. I was trying to get the poster to just say that he did not know if there was actually a law like he stated. Yes, enforcement is a state's issue, and states have the right to implement minimum standards. That is as it should be, given that the Fed cannot even keep track of....well, never mind.
Thank you for the answer, though. BTW, do you know Kevin Holt in Mesquite? If you see a very clean '08 JSB coupe, it is probably him. My former car that I sold him. Nice guy, plays a lot of golf.
Don't know him, but I live right down the street from the 19th hole of one of our golf courses and think I've seen the Vette a couple of times.
I have searched for the link and came up empty. I do remembering reading that it was illegal to change a oem emission component unless it is faulty. I understand that mufflers are ok it is back from them that needs to meet laws.
Air cleaners, cats etc.
I understand the some aftermarket parts have applied for CARB # showing compliance.
There is data collection going on that will show if a car has been tuned, this is the future maybe become another issue point.
