Alignment
Old Jul 2, 2018 | 03:03 PM
Roger2013GS's Avatar
Roger2013GS
Default Alignment
Recently picked up '13 GS. I see a slight camber issue in the rear and ride height too low in front. Anyone recommend a good, Vette alignment shop around Rancho Cucamonga, CA?
Old Jul 2, 2018 | 04:24 PM
hrt vlv's Avatar
hrt vlv
Can't help with recommendations, how do the tires look for wear? Sounds like an aggressive set up.
Old Jul 2, 2018 | 04:40 PM
Roger2013GS
Rear tires have more wear on the outside than the inside of tread, both sides. Too much negative camber, but nor real bad. I suspect someone lowered the front about 1". Rear tires getting to wear bars at 20k, but I want it brought back to spec before replacing rear tires
Old Jul 2, 2018 | 04:47 PM
Homer3D's Avatar
Homer3D
Here are the Pfadt Corvette Alignment Recommendations
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
Old Jul 2, 2018 | 05:08 PM
Roger2013GS
Perfect! Thank you for the specs.
Old Jul 2, 2018 | 06:13 PM
FloridaC6's Avatar
FloridaC6
Subscribed
Old Jul 3, 2018 | 06:59 AM
g's13 GS's Avatar
g's13 GS
I also have a 13GS, I went with stock alignment, told the tech, set it as neutral as possible. I have 15k miles on the tires they are all wearing evenly.
Old Jul 3, 2018 | 07:05 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
The stock alignment for a GS is different than the stock alignment for a base model. I suggest using either the base model alignment or the Pfadt Street Spec alignment. Which ever one you use make sure they alignment it exactly on spec and not within tolerance. I wore out my original GY's at 14,000. I replaced them with Bridgestone Pole Position's and had the Pfadt Street alignment applied. The tires have 30,000 miles on them and are wearing even.
Old Jul 3, 2018 | 11:56 AM
Roger2013GS
Agree that it must be right on spec. Any camber issue will be evident in short time on tires that are 13" across the tread. Thanks for your input.
Old Jul 4, 2018 | 11:58 AM
GrandSportRob's Avatar
GrandSportRob
I bought my 13 GS new and the tires were balding in 9k miles from the aggressive factory alignment. Did the pfadt street alignment a few months ago with my new Continental tires. I’d look for a reputable Vette shop or a Chevy dealer that sells a lot of Vettes and get it done there. I took a printout of the pfadt specs to my dealer and had him do a street alignment on mine.
Old Jul 4, 2018 | 12:28 PM
Roger2013GS
Thanks, Grand Sport Rob. A friend of mine with a C6, Z06 runs Continental and has been pleased with them. Hope yours are working out for you. I'm also going with the street specs.
Old Jul 6, 2018 | 02:33 PM
billmoore48's Avatar
billmoore48
You might want to look into Precision Alignment & Brake in Temecula. Scott is the owner and a hands on mechanic. On my 2011 GS, he made a small, non-stock adjustment that took care of a drifting problem I had. Good guy if you can make the drive.
Old Jul 6, 2018 | 03:23 PM
Roger2013GS
Thanks Bill. I don't know if I want to drive that far. I suspect I can find a good shop closer to home.
Old Jul 9, 2018 | 09:07 PM
Celticknot's Avatar
Celticknot
Are the pfadt alingment specs different from the base model to a GS?
i am putting on new michilen pilot sports 4s on my GS this week. Want to get an alignment done want to make sure I use
the correct street spec. Any help?
Old Jul 11, 2018 | 07:53 AM
Celticknot's Avatar
Celticknot
Does anyone know if the GS has different alignment pfadt specs than a base model?
Old Jul 11, 2018 | 10:56 AM
bibbster's Avatar
bibbster
Ditto
Old Jul 11, 2018 | 03:48 PM
Pete2k_Z28's Avatar
Pete2k_Z28
Also would like to know this as I’m looking to get my GS aligned ASAP with the PFADT specs.
To Alignment
Old Jul 16, 2018 | 02:48 PM
Celticknot's Avatar
Celticknot
I spoke with Pfadt engineering today. According to the person I spoke to, their recommended setting that are published only applies if you have their coil over shocks on your car. They have no recommendation for alignment specs for a factory suspension.
Just thought I would share. Has anyone seen anything different?
Old Jul 16, 2018 | 02:49 PM
bibbster's Avatar
bibbster
Oh crap. Just had mine done Friday.
Old Jul 16, 2018 | 02:52 PM
Sox-Fan's Avatar
Sox-Fan
The Pfadt company that you spoke to today is not the same company that published those specs years ago.
