Service Active Handling System
Old Jul 12, 2018 | 10:53 AM
wdweos's Avatar
wdweos
6th Gear
Default Service Active Handling System
My 2009 C6 displays Service Active Handling System on the DIC , I have no handling problems, how do I turn off the "Service Active Handling System" in the DIC ?
Old Jul 12, 2018 | 11:46 AM
RichKiss's Avatar
RichKiss
The solution is to get fixed whatever is causing the problem. Could be anything. Needs to be hooked up to a Tech2
Old Jul 12, 2018 | 12:34 PM
QuickSilverC6's Avatar
QuickSilverC6
I have the same issue I was told it might be the ABS Module when they scanned it. I just need to find time to take it in for repair.
Old Jul 12, 2018 | 04:37 PM
John A. Marker's Avatar
John A. Marker
Get someone to read the codes with a TECH 2. I had the same thing and the code indicated it was the left front ride height sensor. Bought the sensor from Rockauto and replace it myself.....easy replacement.
Old Jul 13, 2018 | 12:51 AM
HOXXOH's Avatar
HOXXOH
Push another display button and the message disappears. If it returns in 10 minutes, you have something broken/wrong. Otherwise ignore that the message happened.
Old Jul 13, 2018 | 06:08 AM
Dano523's Avatar
Dano523
Tech II to pull the DTC code#.
Hence code # will tell you right where the problem is, and could be as simple as corroded connector pin that needs to be cleaned alone.
Old Jul 13, 2018 | 07:55 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Have you recently disconnected your battery? I ask because whenever I do, I get that come up. I turn off and restart and generally will go away and not come back
Old Jul 13, 2018 | 09:43 AM
JockamoIPA's Avatar
JockamoIPA
Do you also lose ABS?
Old Jul 18, 2018 | 04:42 PM
wdweos's Avatar
wdweos
6th Gear
Had to take it to the dealer, scanned it, found steering angle sensor off center. Recentered steering angle sensor, relearned sensor position. $171.67 Problem fixed.
Old Jul 18, 2018 | 04:45 PM
JockamoIPA's Avatar
JockamoIPA
You were lucky. Mine was the steering position sensor and to right rear wheel speed sensor.
To Service Active Handling System
