Heads up
Old Jul 16, 2018 | 07:52 PM
belsy's Avatar
belsy
Default Heads up
Just installed the reverse lock eliminator on my 06 6 speed after putting it back together my heads up does not work...HELP it worked before I went into the dash / cluster area, what could I have done during the process?? Thanks in advance.......
Old Jul 17, 2018 | 12:46 PM
Dano523's Avatar
Dano523
First off, why the reverse lock eliminator, since the the lock is there so you don't shift in to reverse with the car moving forward.
Hell, if you don't want the reverse lock, you can just turn it off in the tune to start with.
Really, the only place I could see such coming in handy, would be on a 2005 car where you have to shift to reverse to shut off the car, and since the Trans has two reverse switches, its just the reverse switch wiring, not the back up lights that you are tapping into.
So being a 2006 car with single reverse switch, need to see your install wring diagram for the device to start with, and what wires you are tapping into, to try to solve the problem.
