Slow start ZO6 LS7. Solution!
Solution: After watching the attached video on YouTube, I bought a Powermaster high torque mini starter. We installed it yesterday. Wow! The Zo6 cranks and fires on the first try every time. I have tried it hot and cold. I am duly impressed. There will be a starter heat shield added soon,
So far, this engine definitely loves the Powermaster. I am greatly relieved to have this problem apparently solved. Hope this helps someone. Powermaster 9509
Powermaster High Torque Mini Starter (Camaro)
As for starter motors, what really kills the is the bad ground to the bell housing to start with, which cause more heat through the armature wires, and can get to the point that you burn out a set of coil windings by keep running the start when it time to pull it apart to clean and lube it isntead. Also, with this much draw on the start, put a huge drain on the rest of the modules, and why even with the motor cranking, the spark releated modules don't have enough power to control the spark correctly to start with.
As for high torque starter, if you have bumped the displacement of the motor, or increases the compression ratio, then yes on the needed for a high torque starter to begin with. But for a stock LS7, oem starter will work fine if cleaned and relubed as needed isntead.
Doesn't 'sound' too complex and probably a good first step for slow starts.
Just had a cam/heads/tune on my 60K LS7 & experienced a couple sluggish starts, in spite of always tendered & 2 yo Delco.
Cam? Battery? Starter?
IF this becomes an issue might try the Optima first, obviously it fits Z06.
VS headache locating someone capable & willing to rebuild a starter, a good choice.
Hence if you took auto shop in high school, the first thing you learn is how to rebuilt a starter your first week of class.
For the rest of us, dad just handed you the starter to rebuild as a lad much younger than that, while you went to get him another beer as he was working on the rest of the Kart instead.
Hence both timed events, and you better not take too long on either the starter rebuild, or getting him another beer in the first place .
