Here we go again!!
Today, my wife and I drove from Mesa to Tucson so that I could get a Global Entry Interview (Phoenix was booked until Oct). The car ran fine all the way down (128 miles door to door, all but 6 miles on the freeway). In Tucson I parked in covered parking ambient temp was about 98-99 according to the car. Total time parked was 1 hour. We drove about a mile to a small restaurant for lunch and I parked in the sun, car reported about 101 or so. Spent about an hour in the restaurant and when I tried to start the car it started and then immediately the engine died, with reduced engine power and check traction control in the DIC. Another symptom is that the car will not shut off, it will only go to accessory mode or on (not running). I disconnected the battery and left the hood open for 10 minutes, both positive and negative, reconnected the battery and the car was in the same condition, thinking it was in accessory mode. I then disconnected the battery and left the hood open again, and we let it sit for 30 minutes. I reconnected the battery, the car started and ran OK. No messages in the DIC. I drove home without an issue. Now the real troubleshooting will start.
I will check with Tech2Win tomorrow to see if there are stored codes, I know the battery cables are tight at the battery, I don't know about the other end of the cables yet. The oil, coolant and transmission temps never get excessive, at least I don't get temp warnings. I do have a question for the gurus here: Do you know what the underhood temperature might get to in 110 ambient, city driving with a stop every mile or so for a traffic light, speed 45 to 55 when not at a light, AC on. I checked my oil level yesterday after returning home and could not hold on to the dipstick without some protection for my hand.
I am going to make an appointment to bring the car to my local guy, yes the same one that assured me it was the battery the first time this happened but this time I will have some very specific questions for him and very specific areas I want him to check I know other people seem to have solved the problem by replacing the ECM. Is there any way to test the ECM and BCM either in or out of the car or is this solution just a WAG? I guess I am asking for help with troubleshooting suggestions, battery cables, underhood fuze block connector, BCM connector, ECM connecctor etc. what else? Thanks in advance for any help you can give.
Anybody???
Anybody???
EBCM C0242 PCM indicated TCS malfunction
Possible causes
Faulty Electronic Brake Control Module (EBCM)
EBCM Harness is open or shorted
EBCM Circuit poor electrical connection
Faulty Engine Control Module (ECM)
P0601 is defined as Internal Control Module Memory Check Sum Error. This refers to a fault in the internal control memory of the PCM.
Don't know about you, but at this point in my life, I'm tired of trying to diagnose and fix problems where the technology has moved way beyond my pay grade. At this point, I would be finding a shop who would guarantee that their diagnostics and proposed fix would solve the problem, so that if it didn't, you either get a refund, or they continue to fix the problem without further charge to you. At least one GM dealer will do this who is local to me and will warrant their work and parts. This is the purpose of the diagnostic service charge that GM charges, and which everyone whines, moans, and bitches about. Regardless of what they SAY, get it in WRITING. Just my .02
Ideally you've access to a crackerjack electrical tech, it's crucial tech knows these codes in case they disappear.
Methinks issue can & will be resolved through these codes.
G/L, update please.
Possible causes
G/L, update please.
I will update as things progress.
I had another thought though. I thought that reduced engine power meant the car would stay running, we just didn't have full power. In my case, when I got the reduced engine power DIC message, the engine shut off. I was lucky that I could pull over. The owners manual does not mention that the engine might shut off when that message appears, quite the opposite.
Definitely. Those problems that start piling up one after the other along with your money piling up after each false and wasted diagnosis can really become discouraging. You know, it’s possible you have a bad throttle body also. You’d be surprised, but the computer will display this reduced power message in some cases because it senses something isn’t right with the engine and the severity completely depends on which of the pieces of the engine is malfunctioning. If it’s lets say a plug wire is disconnected it may still run but have reduced power while running, but if it’s something like a bad throttle body, and the air is not being let into the engine properly, it will cease to run.
I do hope the ECM replacement does the trick for you, let us know either way!
I did keep the ECM they removed. I want to open it to check the boards. It appears to be easy to do, the lid is held in place by four torx screws but it also has what appears to be a thin layer of silicon as a gasket to keep crud from the inside. That stuff is tougher than glue. Any suggestions of how to pry the lid off without bending the crap out of it?
