i went to start my 2006 Corvette Coupe this morning. I last drove it last Tuesday. Acted normal. Until I pressed start button. A small click and nothing. Tried several times. Same response. Then said no fob recognized. Got other fob. Then same single click, nothing else.
Dash lights and radio come on. Fobs allowed me to unlock door and get in. Driver Window went down some. Won’t go back up. Neither electric windows will work.
Any ideas??
Harry
could this be a weak battery going bad?
Reason: Adding comment
How old's the battery? Use a tender when parked for extended periods? Ever use a tender?
Bet a new battery's in your immediate future, Harry.
Many of 'The' symptoms are present.
Any ideas??
Harry
should I try to jump off? Or just put new battery in. Just got battery in spring of 2016?? But don’t drive car every day.
Can't hurt trying, see what happens.
C6 literally eats batteries, especially for those used in hot climates.
As suggested it can be tested, for free, at most parts stores, but it isn't always accurate.
As I said, my money's on bad battery.
Many members, myself included, use Deltran Battery Tender Plus, there're many decent ones available though.
Trick is using it. Have battery checked and/or replaced.
