Supercharging
Old Sep 1, 2018 | 05:52 PM
Bone stock's Avatar
Bone stock
Default Supercharging
What would be the best 2000,s Corvette to supercharged
Old Sep 1, 2018 | 07:47 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
All of them.
Old Sep 1, 2018 | 08:20 PM
BlindSpot's Avatar
BlindSpot
2006 to 2013; better range is 2008 to 2013.
2005 can be done but because of its unique (E40) ECM, the tuning will be more difficult and you'll need to work around certain sensors on LS2s.
Old Sep 1, 2018 | 09:07 PM
Patriot Six's Avatar
Patriot Six
I would choose one with an LS3.
Old Sep 1, 2018 | 09:44 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Yup .... 2008 and later got the LS3
Old Sep 1, 2018 | 10:40 PM
saplumr's Avatar
saplumr
There’s not much difference between them.
Old Sep 2, 2018 | 03:09 AM
Icecap's Avatar
Icecap
Old Sep 2, 2018 | 08:03 AM
Dano523's Avatar
Dano523
2006 and up.
Hence 2005 had a weaker differential, and when you looking at 600 Plus HP that the LS motor is going to make with a S/C the stronger the diff, the better off you are.
Hence on the 2006 diff and upwards, ribs where added inside the differ to strengthen the case to begin with.
So on the weaker 2005 diff, you can put enough pressure on the pinion gear against the ring gear that is causes the case to crack the case apart with enough traction on lauch.
As for the later diffs, you still not out of the woods, since you get into wheel hop conditions where the tires is spinning, and the bites, it too can put enough pressure on the diff to crack the case as well.
As for types of super chargers, you have the TVS root types that puts the motor at max torque right off throttle, and then the centrifugal type S/Cs that give more of a mid to high range increase power hit isntead. For street driving/road course work where you are grunting the motor out of a corner, the TVS-23 is the better choice since you are already on boost/torque from idle up. For drag/rolling racing type use where you are going to be playing rev ranger with the motor for that type of use, then the centrifugal type S/Cs would be better isntead.
As for top end power that some will say that the centrifugal will produce more than a TVS blower , with the TVS2675 on the market, it will hold it own against any centrifugal SC on the market for not only top end power that you want to throw at the LS motor, but will have higher HP , and torque from idle to mid-range RPMs as well.
As for LS2 or LS3, LS3 block is stronger, has more displacement, and since it has lower stock compression to start with, you can throw more Boost at the LS3 to produce more power safely instead. As for how much power on a stock motor, again all depends on the type of driving you are doing. If for road course work with say TVS 2300, about 650hp is all you want, since your going to be on boost for longer periods, and a hell of lot more of them in a short period. If for strip use with a centrifugal unit since you will only be on boost for a couple of seconds, and not over and over again within a min, then draw the line about 750hp on a stock motor.
Also to add, if you are planing on anything over 550hp with S/C at the crank, either convert the car over to E85, or add in a meth kit.
One last thing, and before you strap in a S/C to a vet, work from the tires inwards, back towards the motor, so the car is ready for the added power.
Old Sep 4, 2018 | 04:01 AM
73DBG's Avatar
73DBG
Tires in-ward is great advice, I think the idea of a blown vette sounds better in theory to most, when you actually have one and realize all the other systems that need to be highly modified for best relatively safe results the money sure does jump out of your wallet real quick like.....cooling that bad boy down....that's gonna cost a few extra G's....fuel system.....well sky's the limit on that, but easily another few G's on the low end......you start getting into forging the bottom end.....$$$$......ask me how I know lol....I have a boosted ZO6 so the solutions to my problems are a little more in depth and even more extra G's............but I believe the post earlier answered your question best. "What would be the best 2000's vette to SC"......."ALL OF THEM" is correct.
Old Sep 4, 2018 | 08:58 AM
Unreal's Avatar
Unreal
2009-2010 ZR1. Really easy, as they come factory with one.
Old Sep 4, 2018 | 11:02 AM
Eritosthenes's Avatar
Eritosthenes
Absolutely work from the tires inward. I replaced my Z51 brakes with Baer Eradispeed -- more "whoah" before the "GO!". With a supercharger you must pay special attention to engine cooling. A supercharger has an intercooler that is typically mounted forward of the air conditioning condensor, which itself is mounted forward of the radiator. Even a few minutes at full boost will heat soak the engine something fierce. If you decide to add a supercharger, I would strongly recommend changing out your stock radiator with a DeWitt's double-thick replacement (link here). And be sure to pin the harmonic balancer to the crankshaft. The one-time bolt that secures the HB cannot hold back the torque of a supercharged LS at WOT. It will slip and the result will be ugly.
Old Sep 4, 2018 | 12:17 PM
73DBG's Avatar
73DBG
Did you see that deal I got on ID 1300’s? It’s on my FIC VS FIC thread.....😆
Old Sep 4, 2018 | 01:10 PM
Unreal's Avatar
Unreal
Yah, if I would have known I would have sold you mine for that so I could goto 1700s. Great choice though. Well worth it.
Old Sep 4, 2018 | 01:32 PM
73DBG's Avatar
73DBG
thats what happened with the guy who had these, realized no way those would support his F1X, needs the 1700’s also, I think they installed them for one test to confirm so basically brand new
Old Sep 4, 2018 | 02:39 PM
redzone's Avatar
redzone
Originally Posted by Dano523
2006 and up.
It's beyond me why you aren't a tech contributor on this site. You sir, know your sh*t.
Old Sep 6, 2018 | 01:19 AM
Bone stock's Avatar
Bone stock
Default Overheating
Thanks everybody for responding it has been very helpful there's been talk about overheating is that daily driving or is that more serious circumstances
Old Sep 6, 2018 | 01:24 AM
Bone stock's Avatar
Bone stock
I'm also going to put a free flowing exhaust on I will assume that will help the heat situation
To Supercharging
Old Sep 6, 2018 | 02:07 AM
73DBG's Avatar
73DBG
F/I is going to make cooling an issue period, some of the guys who are giving you advice now gave me similar advice when I asked these cooling issue questions, Unreal had a few grand in his cooling system alone, I do as well, now you can look on line and find aftermarket radiators that come with dual spals and spend 800-1000 and you’ll still have a cooling issue(this refers to in traffic, city driving) if you’re running hot at 45mph+ you’ve got other issues a radiator and dope fan won’t fix. Use the biggest full size radiator and I can only advise the prospeed set up(it’s not cheap $900) I believe there are one or two more options but I doubt you’ll find those by searching online, more of a specialty custom(ish) set up and even more than the prospeed, some of these guys could give you specifics if you needed that route. I already had a blower set up on my ZO6 when purchased so I was working with what I had, Dewitt’s short cut radiator as well, full size works better. In your case I’d try and limit these foreseeable problems beforehand. A&A’s kit has a helpful solution when it comes to the intercooler(which is one of the main problems) most set ups the intercooler is blocking all the incoming air to the radiator, A&A intercooler is mounted at a rearward leaning angle and has a built in air scoop to force good air to the radiator, that and the angle helps get some through. If I was buying to put on a vette I’d go with an A&A kit whatever the biggest incooler they offer, largest diameter piping and a prospeed dual spal. If you want the trifecta off cooling throw in a meziere high flow water pump. I’m still new to this forum, but ask me how I know all this in such a short time of being a blown vette owner......some mods just aren’t created equal, some you’ll have a list of choices that are all good and it’s just preference, cooling and fuel my advice is take the advice of the dudes who have been there done that tried all the cheaper quick fix options only to end up spending more money and more down time in the shop. Cooling and fuel are most definitely ones to spend the money up front and do it right once. Good luck bro! Boosted vette’s are a blast that’s for damn sure!
Old Sep 6, 2018 | 07:23 AM
BlindSpot's Avatar
BlindSpot
I do not agree with this. FI mods can go from mild to wild. A small A&A (V3 Si-Trim) kit on an LS3, tuned well, can produce 550-570 hp at a modest 6 lb. boost. That's what I did, and I drove it around Phoenix in the dead of summer (as high as 115* ambient air temps) and never saw more than 215* with a stock cooling system. The only change was a 160* Tstat and tweaking the fan in the tune. I did the install and the tune, learned how to get the fan correct and cooling was not an issue. It's a completely different story if the goal is 700 hp to 1200 hp and beyond and trying to drive that around on the street. Without understanding the OP's end goal, this blanket statement isn't accurate.
Old Sep 6, 2018 | 10:20 AM
73DBG's Avatar
73DBG
My apologies, let me make the statement more accurate.....Almost all F/I set-ups will experience cooling issues(except for maybe one guys) and I'm glad to hear his blower set up is cooling effectively with a completely stock cooling system. I'm not really sure how the 160 thermostat plays in to helping with cooling? Also I'd suggest you do some research on this matter, don't take my statements as fact without comparing it to others. A simple search on the forum for "cooling issues" will provide you with tons of reading material, and if you do this search I'd love to know how many threads you find where people say "My F/I build has completely stock cooling system" and it works perfectly, or "Only thing changed for cooling purposes was the fan settings and 160 thermostat" and it works perfectly. Vs. "Here's specifically what I did to help with coolant temps.....list of mods/upgrades" "These were my idle temps in traffic before the changes vs after the changes/upgrades.
