441 ls3
Old Sep 8, 2018 | 05:46 AM
jobberone's Avatar
jobberone
jobberone
Default 441 ls3
can you bore and stroke to 4.125? Notch block? Or do I need LS7,LSX, or Dart?
Old Sep 8, 2018 | 07:22 AM
sccaGT1racer's Avatar
sccaGT1racer
The max bore size on a ls3 is 4.070. If you go to a ls7 block the max bore is 4.130.
Old Sep 8, 2018 | 08:29 AM
vague's Avatar
vague
Below is a copy and paste from HPR
The HPR 442 is one of our own designs and features some exclusive components only found here. Erik designed this package to extract the most displacement from a stock LS3 engine block without having to go through the expensive of sleeving the block. The 442 features a 4.070" bore and a huge 4.250" stroke forged crankshaft.
https://horsepower-research.com/coll...uminum-442-ls3
Old Feb 26, 2019 | 09:24 PM
silversrt's Avatar
silversrt
Cruising
how much power can this block hold on nitrous and boost? I have full bolt on ls3 h/c/I trying to be close to 650 hp n/a, is this possible or do I need the ls7 block to get there?
Old Feb 27, 2019 | 10:00 AM
Garry in AZ's Avatar
Garry in AZ
There are lots of stock bottom end LS3's that are making well north of 750 HP quite reliably.
I've seen a stock LS3 bottom end handle 1100 HP dyno runs, but in my opinion, that isn't a good idea.
But for 650-700 HP, the stock LS3 bottom end is plenty strong. The weakest link in a NA "bolt-on power" LS motor are the hypereutectic pistons. They won't tolerate much detonation so make sure your combination is dialled in.
To 441 ls3
