To Buy, Or Not To Buy .... 2005 M6 Coupe
Another satisfied 05 owner here. Bought mine 2 years ago this month. Been great. 6 spd manual 1SB both tops loaded with everything except Nav. My budget was also 20k and spent less on a like new 05. Sure I would have liked newer but it wasn't in my budget. And since 05's look like a 13 I figured I would eventually upgrade to a C7 in time. No regrets at all.
Received 4,558 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I can only share my experience with the 05. GM admitted to me that the electronics were problematic. They had problems with the XLR at that time as well. A friend of mine had his bought back due to electrical issues. Good luck to the original poster if you decide to buy. Looks like a beautiful car.
Can you "really" expect a 13 year old car not to have problems? I have a 05 Z51 6 speed with 75K miles. When purchased every thing worked as it should, got 20+ MPG as well. Bet you can't find a 05 Honda, mustang or camaro in the same shape.
Always Shiftin'
C5 of Year Finalist (stock) 2019
I love my 05 convertible. Runs great, looks great. Don't listen to the haters. If you get an LS2, they will tell you you should get an LS3, If you get a C6 LS3, they will tell you you should have bought a C7, if you do that, you should have bought a Z06 then you should have waited for the mid engine C8.. It never ends with some of these idiots.
Buy what you can afford, like and have a good feeling about.
2016 C2 of Year
Since I'm the only one in this thread that had anything to say about potential issues with the 05, should I assume this is directed at me? I expressed an objective response based on my personal observations. I'm neither a hater or an idiot.. This Forum never ceases to amaze me with the name calling if someone express an opinion contrary to yours. I'll refrain from any name calling.
This was directed at the people who seem to have to give me their opinions of my purchasing an early model year C6 wherever I go.. Wrong year, wrong engine, wrong transmission, etc etc. Just giving my opinion to the OPs question.
capevettes (09-13-2018)
Always Shiftin'
Needs rear struts and tires are not too great. And a couple of other minor issues. I can get good deals on parts where I work but it brings the total to around $17,500 (if I get the tires I want). I think it is still worth it.
Thoughts?
Thoughts?
Not sure on rear strut cost, but tires will run ~1200 if you want Michelin run flats (highly recommend as I put AS3s on my car). Just for reference, I bought my 05' 2 years ago for 21,500 with 53K. Sounds like a lousy deal in comparison, but very happy with it -- now have 65K. What has happened since my purchase:
Tires and brakes (base brakes were squealing bad so went to ceramics)
MAF sensor
Crank Position sensor
Fuel pump relay
I expect some issues being 13 years old and storing over the winter. I am not a fan of super low miles or high miles --- I think you have a great opportunity to get into a nice car for a great price!
MAF sensor
Fuel pump relay
Had mine almost a year and a half. Replaced BCM and ignition switch. It had brand new tires when I got it at 73000 miles. Enjoying it, no problems.
#34
I've got a Magnetic Red 05. I love it. Would liked to have paddle shifters but what the heck. I have black interior but cashmere is really nice looking.
Magnetic Red looks so elegant. And I've ALWAYS liked the four post steering wheel more than a three post.
Go for it!!
Go for it!!
#35
Always Shiftin'
So close! As you could probably tell I was getting pretty close to pulling the trigger on this 2005.
HOWEVER, since my last post yesterday afternoon we have found several more issues....
The sad part is it is an awesome color. It drives great. Clutch operation and shifting is flawless. Acceleration is strong. Ride is a little rough, but probably can be attributed to the tires and rear struts.
THANKS AGAIN for all the great feedback (good and constructive)!! ANd listening to me thrash through this process!
THE SEARCH CONTINUES!!!! Stay tuned!!
- Inoperable memory seat controls.
- Driver side seat heater,
- Front emblem would have to be replaced (red portion significantly faded)
- CD player portion of the radio not working,
- Bad radio volume control.
- The passenger side lower radiator mount bracket bent with broken welds. Looks like it had a significant impact to a curb or some other obstruction.
- Also noticed a significant rust hole just under the right side exhaust tip in the muffler body.
- Brake pads are OK, but close to needing to be changed.
- In addition to the tires and rear (realistically rear and front) struts mentioned earlier
#38
Based on what you said I'd probably keep looking, and/or bring up these items up to get a lower price. Just to play "devils advocate" and if you do your own work these items are not all that expensive to fix.
- Inoperable memory seat controls - could be the connector under the seat, the battery was disconnected (deletes settings) or the e-brake switch not connected.
- Driver side seat heater - If the e-brake was disconnected that could indicate the console was removed, is the heater switch just disconnected ?
- Front emblem would have to be replaced (red portion significantly faded) I would not let that deter me from a good deal
- CD player portion of the radio not working, - get a new used one off fleabay, or get an after market with Nav. (Could be why the console was removed)
- Bad radio volume control. (see above)
- The passenger side lower radiator mount bracket bent with broken welds. Looks like it had a significant impact to a curb or some other obstruction. (all c6 owners hit a curb at some time at least once .... what's the cost to fix - deduct from price. You can buy a new mount and bolt it in.)
- Also noticed a significant rust hole just under the right side exhaust tip in the muffler body. (Cheap loud muffler mod ?) (I'd price in a Corsa exhaust, for example, and get the price reduced)
- Brake pads are OK, but close to needing to be changed.( Who cares? Relatively cheap fix )
- In addition to the tires and rear (realistically rear and front) struts mentioned earlier (Do you mean end links ? ... if so also a cheap fix. I bought mine on Amazon, almost took me longer to jack up than replacement. )
#39
Always Shiftin'
"lesson learned" for sure!!
#40
qikstik
I have had my 05 since 06 it now has 120k on it, of which the last 2k have been very hard miles. The only draw back I have with the 05 is that when you shut the car off before you get out you have to put the car in reverse or the electrical system will not shut down all the way,
and unfortunately it is the only year C6 that has that requirement. and as far as I know there is no disarming it.I have gotten used to it, the problem is most people don't know and if they park your car for any length of time you may get a flat battery.if they don't shift to reverse
2005 C6 base
2005 C6 base
