To Buy, Or Not To Buy .... 2005 M6 Coupe
#41
qikstik
I have had my 05 since 06 it now has 120k on it, of which the last 2k have been very hard miles. The only draw back I have with the 05 is that when you shut the car off before you get out you have to put the car in reverse or the electrical system will not shut down all the way,
and unfortunately it is the only year C6 that has that requirement. and as far as I know there is no disarming it.I have gotten used to it, the problem is most people don't know and if they park your car for any length of time you may get a flat battery.if they don't shift to reverse
2005 C6 base
2005 C6 base
#43
Its automatic now, and I even do it with my other manual car. Setting the ebrake and putting a manual in gear is something you should always do. If you don't know why you will eventually.
#44
So close! As you could probably tell I was getting pretty close to pulling the trigger on this 2005.
HOWEVER, since my last post yesterday afternoon we have found several more issues....
The sad part is it is an awesome color. It drives great. Clutch operation and shifting is flawless. Acceleration is strong. Ride is a little rough, but probably can be attributed to the tires and rear struts.
THANKS AGAIN for all the great feedback (good and constructive)!! ANd listening to me thrash through this process!
THE SEARCH CONTINUES!!!! Stay tuned!!
- Inoperable memory seat controls.
- Driver side seat heater,
- Front emblem would have to be replaced (red portion significantly faded)
- CD player portion of the radio not working,
- Bad radio volume control.
- The passenger side lower radiator mount bracket bent with broken welds. Looks like it had a significant impact to a curb or some other obstruction.
- Also noticed a significant rust hole just under the right side exhaust tip in the muffler body.
- Brake pads are OK, but close to needing to be changed.
- In addition to the tires and rear (realistically rear and front) struts mentioned earlier
#45
Always Shiftin'
C5 of Year Finalist (stock) 2019
good decision! Continue looking, as you’ve likely realized from input here the early years of the C6 were nothing to write home about, too old, too many miles not to mention the design flaws. Keep looking and test driving, there are a surprising high number of good deals in the off months. The more Vettes you drive, the easier it will be to pick one as a first time owner.
#46
Hi, I enjoyed reading about your search last week. I clicked on your pictures last week and went scrolling to the right and was impressed with all of those great bird pictures! I also noticed a lot of familiar places I recognize such as biltmore house, and several Blue Ridge mountain spots I go to regularly. I was telling my wife about all the great bird pictures that was probably a mistake in posting, but some great talent you have there! Were those all with your phone camera? Amazing! Good luck in your Vette search, good to see you are in checking it out thoroughly !!
MacA1979 (09-17-2018)
#47
Always Shiftin'
Thanks again for the reply!!
#48
Always Shiftin'
I ended up finding a great deal on a real low mile 2004 Torch Red Z06. This thing is awesome!
THANKS AGAIN for everyone's feedback!!
#50
Always Shiftin'
I'll leave a few pics. Hopefully you C6 guys will be OK with this......
#53
#54
I would have to go with C6 but I am biased! Congrats, looks like a very clean C5Z!
#56
#60
