Wanders on freeway
Old Sep 13, 2018 | 11:07 PM
BillBarkerville's Avatar
BillBarkerville
Veteran: Coast Guard
Default Wanders on freeway
I took my 2013 GS on a short road trip this week (650 mile round trip). I've owned it for a year and this was my first chance to get it on the road. I noticed that it seemed to wander no matter what the condition of the pavement was. It has 6,000 miles with the original tires still on it. I seem to remember from my high school days that a car with toe-in would "wander" while minor toe-out helps to keep it in a straight line. Is this my problem? Does this sound like too little toe-out?
Last edited by BillBarkerville; Sep 14, 2018 at 07:38 PM. Reason: corrected mileage
Old Sep 13, 2018 | 11:33 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Check the wear on the inside portion of the front tires. I'll bet it's more worn on the inside than on the outside which you can easily see. I know this from experience from when I had my C6. Couldn't figure out why it wandered so much until I discovered the excessive wear on the inside of the tires. Soon as I got new tires, problem went away.
YRMV.
Old Sep 13, 2018 | 11:55 PM
owc6's Avatar
owc6
Regardless of the tire wear, those shoes are starting to get old. Time for new ones (especially since were talking GY).
There are much better tires out there (starting with Michelin or Bridgestone, IMO). Whether you pick RFs or not.
Most likely (as Ex Red says) the alignment is off.
Old Sep 14, 2018 | 07:42 AM
BadAV's Avatar
BadAV
Both the OEM Goodyear tires and aggressive OEM alignment contribute to tramlining and/or wandering. My Centennial GS did it until I replaced the tires with Bridgestone Potenza runflats and got a Pfadt "street" alignment that is more neutral and encourages long tire life, versus wringing out every last smidgen of handling.
Old Sep 14, 2018 | 07:45 AM
Celticknot's Avatar
Celticknot
Its the tires - mine was doing the same thing with those Goodyear's - swapped out to Michelin's issue solved
Old Sep 14, 2018 | 07:58 AM
Judgebull's Avatar
Judgebull
I have a 13 GS with OEM Goodyears and have not had any problems like this....probably just lucky
Old Sep 14, 2018 | 03:27 PM
dr_gallup's Avatar
dr_gallup
Actually, toe out causes the wander and toe in keeps it tracking straight. If the tires are worn it's because the alignment is bad, not the other way around. It should track nice and straight on smooth, flat pavement. Get the Pfadt street alignment as mentioned above. And drive that Vette more!
Old Sep 14, 2018 | 07:37 PM
BillBarkerville
Great comments. I really appreciate it.
I checked my tires and the insides of both of them ARE worn more than the outer edges. Hummm.... I think that "proves" that they are toed-out.
So it sounds like my suspicion about alignment was correct. But it should have a tad more toe-in, and not toe-out.
I am seriously tempted to just go to the dealer tomorrow and look at the 2019's. Our credit union is offering 1/2 percent off this weekend only.
Again... thanks. I really appreciate the serious and intelligent responses. This really bugged me over 12 hours of driving earlier this week.
Old Sep 14, 2018 | 09:15 PM
mkitt27's Avatar
mkitt27
Tire wear on the inside edges can be caused by two things. Toe of course but also camber. Excessive toe will wear the inside edges much faster than camber however. A good first step is checking alignment. Also monitor and see if it happens all the time. Older roads get grooves worn and can cause tramlining even if all else is good. Wide tires like on our cars are more subject to tramlining. More aggressive track alignments also increase tramlining hence the reason the Pfadt street alignment helps.
My sports cars regardless of brand always wore front and rear tires on the inside more than the outside. Older 911's really wear the rears on the inside as they needed the camber to keep the rear end from coming around.
Old Sep 15, 2018 | 01:16 AM
phileaglesfan's Avatar
phileaglesfan
Most likely the crap tires that are also old now. However I would definitely get an alignment. You really have to be careful with the toe setting as too much in and pretty much any out will kill your tires in a heart beat.
Old Sep 15, 2018 | 09:52 AM
weezon's Avatar
weezon
OP has a 13 GS with 6,000 miles. It needs a wheel alignment and that has him thinking of getting a 2019 C7, and the credit Union has 1/2% interest rates? Men, you gotta love our reasoning.
Old Sep 15, 2018 | 10:28 PM
Not So Fast's Avatar
Not So Fast
My 11 GS did the "tramlining" (sp?) even after getting an alignment, had Nittos on it that were in decent shape, also had a small vibration at 80mph after balancing.
Then I put Hankooks on it with road force balance, alignment and all's good, goes straight and no vibration
NSF
Old Sep 16, 2018 | 09:37 AM
cnw's Avatar
cnw
Tires
To Wanders on freeway
