Quickjack and pucks
Old Sep 18, 2018 | 02:20 PM
hms's Avatar
hms
Default Quickjack and pucks
Hi. Do you use jacking pucks with your quickjack ?
Old Sep 18, 2018 | 03:00 PM
SixAddict's Avatar
SixAddict
Yes, they must be used whenever jacking with anything quickjack or floor jack.
Old Sep 18, 2018 | 03:09 PM
sabastian458's Avatar
sabastian458
If you use the quick jack rubber blocks you may not be able to use typical “jacking pucks” like most here own for use with a regular jack. My car is just low enough that I could not use anything but the short rubber block provided with the quick jack. I would not use jack pucks only with a quick jack, you will damage the rockers and or the floor boards.
Old Sep 18, 2018 | 03:34 PM
SixAddict's Avatar
SixAddict
I use the jacking pucks with the lower rubber blocks with my quick jack, haven't had any issues.
Old Sep 18, 2018 | 04:42 PM
danzio56's Avatar
danzio56
Same here, works exactly as it should.
Old Sep 18, 2018 | 05:43 PM
Eritosthenes's Avatar
Eritosthenes
I use only the 5000's small rubber blocks on Red's jacking points. They fit and work perfectly. There's simply no reason to use old-style jacking pucks with a quick jack.
To Quickjack and pucks
