Breaks
Old Sep 20, 2018 | 09:48 AM
kperez's Avatar
kperez
Default Breaks
Hey guys im looking for some recommendations for some aftermarket brakes for my 2009 2lt base, my current ones are starting to squeak like crazy, any insight would be greatly appreciated.
Old Sep 20, 2018 | 09:57 AM
Tokuzumi's Avatar
Tokuzumi
Are you just looking for pad replacement? Or are you looking for a brake upgrade (new calipers, larger rotors, pads)?
For pads, get EBC Yellow Stuff.
Old Sep 20, 2018 | 09:58 AM
cmonkey713's Avatar
cmonkey713
You can use the search function here to read the hundreds of threads on brakes. If the car is a daily driver you could go with a good ceramic low dusting pad. Numerous suppliers carry these pads and are usually available at your local auto parts store.
Old Sep 20, 2018 | 12:07 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Do you need pads and rotors or just pads? How many miles on the rotors? What are you using the car for? I'm guessing just street if that is the case I would recommend the Carbotech 1521 pad. A performance street pad that is rotor friendly and low dusting.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
If interested I will be happy to help you out or you can order online here http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out to save 5%.
Part numbers
F: CT731 1521
R:CT732 1521
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Sep 20, 2018 | 01:21 PM
edcologne's Avatar
edcologne
obviously i assume your pads are still present and you're not running metal on metal...
IF you have the z51 or f55 option chances are all you need to stop (minimize) the squeaking is changing to oem ceramic pads.
worked for me and many others.
Old Sep 20, 2018 | 02:17 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
As others have noted, plenty of choices for both pads & rotors. All depends upon your driving style & pocketbook. BUT.....before you jump to spend $$$....are your pads really worn or just squeaking? How many miles on the pads? How much thickness left? Any scoring on the rotors? Pull the front wheels & check the pads & rotors (fronts will wear before rears). If the pads & rotors look good, squeal may just be due to high frequency vibration of the pads under braking. Simple fix is to pull the pads & put a THIN coat of hi-temp grease on the back of the pads (be careful not to get grease on the rotors) & reassemble. Good chance that will cure the squeal & not cost you anything.
Old Sep 20, 2018 | 04:13 PM
HOXXOH's Avatar
HOXXOH
Assuming you only have pads squeaking and not metal to metal, one easy way to stop it, is to go to a safe area and do a couple hard stops from around 60-70 mph to clear off the pads and rotors. Don't do that If you have little to no pad remaining. Check pad thickness first.
Old Sep 21, 2018 | 02:45 PM
TxLefty's Avatar
TxLefty
Part numbers
F: CT731 1521
R:CT732 1521
I'm using these on my 2011 GS. Have about 3,000 miles on them now. I'm a happy customer. Quiet, low dusting, good performance. I don't track the car, but do auto-x.
Old Sep 21, 2018 | 10:03 PM
R_W's Avatar
R_W
Part numbers
F: CT731 1521
R:CT732 1521
I happen to be selling a used set complete with StopTech slotted rotors. I am selling them because I went Carbotech XP8/XP10 for the track and never bothered to take them off. PM me if interested.
To Breaks
