Crank Pulley Bolt Socket
I am in the process of troubleshooting an engine noise and want to do a leak down test. Need to rotate internals using the pulley bolt but the steering rack is in the way. Hoping to avoid removing it so wondering if there is a special tool or someone has fabricated one to do this? Any assistance will be greatly appreciated.
dpigguy (09-28-2018)
That would be the plan. I have an Innovation West harmonic balancer and since the pulley bolt is recessed and the steering rack is directly in front of it, I can't use a socket ratchet combination to turn it.
put the back wheels in the air, put it in 6th gear, and rotate them. plugs out and belt off will help.
That's OK, I do that assumption thing quite often, lol. I'm thinking of using a short socket that will fit in between the bolt and the steering rack and a piece of square rod with the right length to allow it to also fit that space, as I slip the socket over the bolt it will push the rod out and I believe there would be enough surface so I can use an open box wrench with an extension. Maybe?
Mark
Thank-you, never thought about that. I'll try it. It may be a problem because I have a supercharger with twin separate belts and the alternator is driven by a small common pulley.
WW7 (09-28-2018)
