Plastic bag
I'm new to this site and also very new owner of a 2005 corvette....and I had the miss fortune to run over a plastic garbage bag...Not knowing much about the car I kept on driving it...never thought for a moment that the bag was sucked in by the fun...a couple of days later the car over heated..I noticed pieces of that bag sticking out under de front of the car ...I manged to pull the rest of the bag out....But now my fan doesn't run.....I can move it and rotate it with my hand ….but that is it....Does anyone had run into this problem...? any advise on what to check...??..Fuses, madules, relays...etc...Thanks..
it may be melted (probably rock hard ) in place. hopefully not.
Welcome to the love of Corvettes, can't really help you, but here is your owners manual of the web:http://www.c6registry.com/Technical/manuals/2005OM.pdf
Thank you very much for your help...
Rick
Let the car idle until it warms up. If the fan does not kick in at 220-230, then shut it down and troubleshoot further.
Thanks anyways....
The engine cooling fan is a variable speed fan. The engine control module (ECM) controls the fan speed by sending a pulse width modulated signal to the cooling fan control module. The cooling fan control module varies the voltage drop across the cooling fan motor in relation to the pulse width modulated signal.
Cooling fan speed is effected by many different conditions and can be adjusted from 10% to 90% duty cycle (PWM), 90% is considered high speed fan. When multiple cooling fan speed requests are received the ECM uses the highest cooling fan speed of all the requests. The ECM commands the cooling fan ON under the following conditions:
• Cooling fan duty cycle starts when engine coolant temperature reaches approximately 95°C (204°F) and reaches high speed at temperatures above 113°C (235°F).
• Cooling fan duty cycle starts when A/C pressure reaches approximately 1100 kPa (160 psi) and reaches high speed at A/C pressures above 2480 kPa (360 psi).
• At engine oil temperatures above approximately 150°C (302°F) the cooling fan duty cycle will be commanded to high speed.
• At transmission oil temperatures above approximately 132°C (270°F) the cooling fan duty cycle will be commanded to high speed.
• After the vehicle is shut OFF if the engine coolant temperature at key-off is greater than 113°C (235°F) or the A/C pressure is greater than 1720 kPa (249 psi) the cooling fan duty cycle is set to 50%, low speed. If the coolant temperature drops below 110°C (230°F) and the A/C pressure drops below 1660 kPa (241 psi) the fan will shut OFF. The fans will automatically shut OFF after 2 min. regardless of coolant temperature.
I would pull the plug to the cooling fan and first see if the connector is melted inside. They can overheat under load, melt and loose contact. Running a jumper wire, bypassing the plug is a simple repair. If ok, run a direct 12v to the fan to see if it comes on. The 60amp fuse is under the hood. The cooling fan control module can fail and is mounted on the fan housing.
I ask, DID this help in getting your fan working? I want to say welcome to a great forum, spend time here, a lot of great people.
