I took my 2011 grand sport corvette for a drive yesterday when I got home I left a trail of transmission oil up the driveway. The back of the car was covered with a mist of transmission fluid. I went under the car could not find any thing loose but had to add a quart of transmission oil any ideas? Manual transmission
Reason: Forgot transmission type
Check the cooler lines off the trans.
Hence mist of fluid screams that the fluid was under pressure where it was leaking out, and that would be the trans cooler lines that sees that kind of pressure out side of the trans.
