C6 Base model Differential Question
Old Oct 7, 2018 | 04:52 PM
Michael Swaenepoel's Avatar
Michael Swaenepoel
8th Gear
Default C6 Base model Differential Question
Hello all,
I've recently discovered that my C6 has a small leak from the seal on the right side of the rear differential where the CV axle goes in. I haven't been able to find a part number for replacement. Any suggestions? Also, since I'm in there, should I replace anything else since it'll be torn apart for the gasket replacement?
Old Oct 7, 2018 | 05:58 PM
wayback's Avatar
wayback
Try 19259473. Looks like it can be replaced from the outside.
Old Oct 7, 2018 | 08:38 PM
Michael Swaenepoel
8th Gear
Thank you! Is there anything else I should replace while I’m taking it apart just to be thorough?
Old Oct 7, 2018 | 08:43 PM
C6ToGo's Avatar
C6ToGo
Not an uncommon repair. One of mine replaced under warranty, and I replaced one that leaked after swapping out an axle.
$25-50 is ridiculous for that seal. A perfectly good SKF seal can be had from Rockauto for 6 bucks.
Old Oct 7, 2018 | 08:47 PM
C6ToGo's Avatar
C6ToGo
Buy a new GM axle nut when you get the seal.
34MM socket is available as a loaner tool if you don't own one.
Check your rear brakes while you are there.
Grease the tie rod if it is a serviceable one.
Replace the diff fluid if it is due.
Make sure shocks and transverse spring look good.
Old Oct 7, 2018 | 10:28 PM
Michael Swaenepoel
8th Gear
Thanks for the info. I have been trying to look the part up on RockAuto, but I can’t find it. Do you happen to know the part number they have for it?
Old Oct 8, 2018 | 07:22 AM
C6ToGo's Avatar
C6ToGo
SKF 15547. Showed 2 yesterday when I looked....now out of stock.
To C6 Base model Differential Question
