power window will not go back up
I have 2006 base convertible. I am able to lower the passenger side window with driver's side switch but it will not raise it back up.. I replaced the switch but problem was not solved. Any Ideas? Thanks
How did you get the window back up? By hand? The window goes up and down on a cable system, I had one of mine go bad on my 05. That could be your problem?
Does it go back up using the passenger side switch? If so and since you replaced the driver side switch, my guess is it's either a bad/broken wire or something wrong with the connection to the switch.
Gscafidi (10-09-2018)
