C6 upgrades
Old Oct 27, 2018 | 02:22 PM
weedester's Avatar
weedester
4th Gear
Default C6 upgrades
I recently did some engine mods on my 08' 6.2. Now I'm a bit concerned about blowing up the rear end and/or transmission. I'm looking for some input on things to consider to upgrade in order to keep what I have from exploding. Thanks in advance.
I forgot to mention the mods that were done...Thanks for the reminder Brenda1.
Upgrades included a cam, methanol injection, ECS supercharger, new pushrods, timing chain, head gaskets, Kook's headers and mid pipes and transmission cooler. Everything else is stock
Old Oct 27, 2018 | 02:52 PM
Brenda1's Avatar
Brenda1
With all do respect, you may want to give a list of the mods. Then, the nice people here can give you an intelligent reply.
Old Oct 27, 2018 | 06:31 PM
FAUEE's Avatar
FAUEE
He did. Blower, cam, meth Injection.
I'd say your best bet is to start saving up for a trans rebuild. You will eventually need it.
Old Oct 27, 2018 | 07:00 PM
449er's Avatar
449er
CF Community Team
The issue with adding go fast parts is that they always find the "weak link in the chain". You may at some time experience a failure of some sort with the drive train depending on how hard you drive the car.
Old Oct 27, 2018 | 07:02 PM
weedester's Avatar
weedester
4th Gear
I don't really hit it too hard right now although I do plan on taking it to the track to get some times on it
Old Oct 28, 2018 | 07:05 PM
HOXXOH's Avatar
HOXXOH
Research so far has indicated you live in Houston, are 56 years old, a male, your car is an '08 base and you've added a supercharger, cam, headers, and a few supporting mods.
This would have been a lot easier if you would have filled out your profile with that info and more, so people don't have to find out these things by other methods, including asking you a bunch of questions, while they are trying to help you.
OK, now off my soapbox.
Would I be correct to think you have an A6 trans, a 2.56 rear gear, and the track you mentioned is a dragstrip.
If so, what tires do you currently have on the car and do you intend to use them at the drags?
Old Oct 29, 2018 | 08:26 AM
weedester's Avatar
weedester
4th Gear
[QUOTE=HOXXOH;1598238869]Research so far has indicated you live in Houston, are 56 years old, a male, your car is an '08 base and you've added a supercharger, cam, headers, and a few supporting mods.
If so, what tires do you currently have on the car and do you intend to use them at the drags?[/Q
I'm not sure of the trans but the rear end is a 2.73 (got that from the tuner). Yes, I would like to run it on the drag strip. I upgraded the rear tires to M/T 305 drag radials and yes, i'll be running them on the srtip
To C6 upgrades
