Tire Pressure
Old Oct 29, 2018 | 06:24 AM
kperez's Avatar
kperez
Default Tire Pressure
For any C6 daily drivers, what do you usually keep your air pressure at for a nice smooth ride?
Old Oct 29, 2018 | 07:03 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
30 psi is the sweet spot for ride, wear and performance.
Old Oct 29, 2018 | 07:14 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Just what the sticker says 30 PSI.
Old Oct 29, 2018 | 08:05 AM
z06clif's Avatar
z06clif
30lbs is what the tires say. Actually they dont say anything.......youve got to read it.....lol
Clif
Old Oct 29, 2018 | 08:14 AM
SXGT's Avatar
SXGT
I personally emailed Michelin because of the sticker on the door vs. the number on the tire debate. Turns out its the sticker on the door and NOT the number on the tires. Go with 30 - 32
Old Oct 29, 2018 | 08:44 AM
cmonkey713's Avatar
cmonkey713
Same as others, 30 to 32. Since the weather is getting cooler they will lose pressure so checking your tire pressure more frequently this time of year is a good idea.
Old Oct 29, 2018 | 09:11 AM
Kenny94945's Avatar
Kenny94945
Firestone RFT Z51 Vert 33 Ft 27 Re.
OP says comfort.
Above pressures work for my driving "feel" and even tire wear with my custom alignment.
Less pressure usually equates to a smoother ride.
Runflats have stiff sides walls somewhat negating that rule.
OP doesn't mention which tires he has.
If OEM Goodyear, yes 30 is proper.
I venture a guess that you could experiment by dropping a few (one to four) PSI to increase comfort.
OP will just have to experiment to find his "sweet" spot.
Have fun and FWIW buy a good tire gauge, ideally one that reads in 1/10 or 1/2 of a PSI.
Old Oct 29, 2018 | 10:24 AM
Bruze's Avatar
Bruze
It shouldn't have been a debate, and it's not another urban myth that somehow may or may not be true.
The number on the tire is the maximum pressure the tire should be run UNDER A MAXIMUM LOAD. The weight of C6 is NOT the maximum load unless you're hauling gravel or something in the back. The last time I looked at a tire (20 years ago) it says something to the effect: XX PSI MAXIMUM LOAD. It's been like this for as long as I can remember.
Since the C6 is NOT the maximum weight, the car manufacturer calculates the proper pressure and puts it on the door jamb. I've never seen where the maximum load pressure was the same as the door jamb pressure.
Old Oct 29, 2018 | 10:55 AM
J.Moore's Avatar
J.Moore
Firestone Run Flats on my C6 and they like 30-32 cold. Anything higher and it gives a much firmer and too firm of a ride.
Old Oct 29, 2018 | 11:27 AM
jrose7004's Avatar
jrose7004
30 psi cold!
Old Oct 29, 2018 | 11:40 AM
HBsurfer's Avatar
HBsurfer
It always amazes me how many people think the pressure on the tire is anything other than exactly what it says , max air pressure.
I assume those same people never see the tire pressure sticker in the drivers door jam that is on every car they drive
Old Oct 29, 2018 | 12:40 PM
Batman75's Avatar
Batman75
Originally Posted by jrose7004
30 psi cold!
No need for the thread to continue.
Where does the idea to experiment or between 30 psi and 32 psi come from?
Old Oct 29, 2018 | 01:15 PM
Vet Interested's Avatar
Vet Interested
What sticker on the door?
Old Oct 29, 2018 | 01:33 PM
HBsurfer's Avatar
HBsurfer
Don't make me come down there!!
Old Oct 29, 2018 | 01:53 PM
Bruze's Avatar
Bruze
Like anyone could tell the difference.
Old Oct 29, 2018 | 02:00 PM
Bruze's Avatar
Bruze
What door? Attachment 48332111
Old Oct 29, 2018 | 07:47 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
I run 30 psi cold in the summer and 32 psi cold in the winter. I want my tires to get to 35 psi hot. starting at 30 psi cold in the winter will only give me 33 or so psi after they heat up. This is to low for me.
To Tire Pressure
Old Oct 29, 2018 | 09:05 PM
dpigguy's Avatar
dpigguy
Firestone RF - run 32 front and 30 rear when cold. Front pressure comes from a member (Wolfdogs) who was a tire engineer and his analysis showed those settings to be optimal for the C6. He was also a fanaic user of Zaino and you could read the time of day on your watch in the reflection of
the car.
Old Oct 29, 2018 | 09:22 PM
Vet Interested
Sorry Tony.
Old Oct 29, 2018 | 09:28 PM
Vet Interested
What door?
Thats why I could not find the sticker.
