Throttle Position Sensor Stall
Old Nov 3, 2018 | 06:28 PM
Rodney Rancik's Avatar
Rodney Rancik
2nd Gear
Default Throttle Position Sensor Stall
A c6 suffering from engine shutdown with fault code throttle position sensor fault. After a few minutes, car can be started again. Can you troubleshoot throttle controls?
Old Nov 3, 2018 | 10:57 PM
LowRyter's Avatar
LowRyter
maybe replace the TPS or look at the connector?
Old Nov 3, 2018 | 11:50 PM
Cherokee Nation's Avatar
Cherokee Nation
What code was it?
Old Nov 4, 2018 | 11:58 AM
Dano523's Avatar
Dano523
Originally Posted by Cherokee Nation
What code was it?
Yep. accelerate pedal is a PITA to pull and clean up it sensor (just replace the pedal assembly with new sensor), but the TB is not isntead.
Also, is the code pointing to a bad circuit, which just may be a problem in the wiring or connector isntead.
Hence really need to know the code number, since it will point you are a specific item that is having a problem to start with.
Old Aug 12, 2019 | 02:36 AM
chevyboy76's Avatar
chevyboy76
4th Gear
ya bro i replaced the throttlebody already car ran good for like 20 minutes then it grenaded again and went into reduced power mode, any ideas? thanks
Old Aug 12, 2019 | 06:37 PM
Dano523's Avatar
Dano523
What DTC code, since it may be the TB that just has to be pulled apart and its internal Stats cleaned up.
Old Aug 13, 2019 | 01:42 PM
chevyboy76's Avatar
chevyboy76
4th Gear
i have replaced the tb and sensor with a new one worked good for twenty minutes then back to reduced power mode,gonna throw a throttle postion sensor at the gas pedal next.... thanks for reply
Old Sep 13, 2019 | 09:59 PM
Tom8100's Avatar
Tom8100
Default Anyone else had TPS (Throttle Position Sensor) issues?
I just got my C7 back this afternoon-dealership has had it since 2 Saturdays ago with "throttle position sensor" issue-that is not counting the 5-6 days they had it previously; my TPS issue started after a routine State of TX car inspection. The TPS was replaced first; then after it went into "limp home" mode 4 times they searched sources for new wiring/harness and connector to "computer"; again it went into "limp home" mode; GM tech support said to replace the main computer; I drove it home (9 miles) without incident....so far.
To Throttle Position Sensor Stall
