NPP operation question...
However, when I drive and the RPMs are above 3500, it doesn't seem like the butterflies are opening. I have not really FLOORED it when doing this, and I'm wondering if you have to have a certain amount of throttle in order for the NPP to open.
I don't think the NPP valves open at a preset RPM.
On my car, the NPP butterflies would only open when you would get on the throttle about half-way or more (needed a good load on the engine).
Even if you downshifted into lets say 3rd gear while cruising at 65 mph ... Yes, the RPM would then be high, but the valves still would not open because there was no load on the engine.
In fact, you could be at a dead stop in neutral and hold the throttle down to achieve a steady 5,000 RPM, and the valve still would not open ... (no load on the engine)
The NPP is the RPO (regular production option) code for the bi-mode exhaust that is available on the coupe and convertible. This exhaust is modelled after the exhaust on the Z06. The exhaust uses a butterfly valve over one of the exhaust exit pipes (two total, one per muffler) to vary the exhaust output. It works similar to exhaust cut-outs popular on the street rods.
The exhaust control is operated by engine vacuum pressure. The system is tied to the pcm and monitors rpm and throttle position to measure "driver intent". There is no switch manual switch on the OEM system. One pipe is fairly unrestricted and by-passes the baffle system of the muffler. The other pipe is restricted and only passes exhaust gas through the baffle system of the muffler.
Under normal circumstances the exhaust valve is closed and it routes the exhaust gas out of the other pipe after it passes through the baffle chamber of the exhaust. In this case it is quieter. If the driver accelerates hard the valves will open at 2,800 rpm as long as the driver is above 80% throttle. Between 30% and 80% throttle the exhaust will open during acceleration at 3,500 rpm
NPP is the Regular Production Option (RPO) code for the Dual Mode Exhaust Option first offered to non-Z06 Corvettes in 2008 as an $1195 option. LS3 engines equipped with NPP get a bump in horsepower rating from 430 to 436. Modeled after the exhaust on the Z06, the exhaust uses a butterfly valve over one of the exhaust exit pipes (two total, one per muffler) to vary the exhaust output. It works similar to exhaust cut-outs popular on the street rods.
NPP Exhaust Valves
The exhaust control is operated by engine vacuum pressure. The system is tied to the pcm and monitors rpm and throttle position to measure "driver intent". Under normal circumstances the exhaust valve is closed and it routes the exhaust gas out of the other pipe after it passes through the baffle chamber of the exhaust. In this case it is quieter. If the driver accelerates hard the valves will open at 2,800 rpm as long as the driver is above 80% throttle. Between 30% and 80% throttle the exhaust will open during acceleration at 3,500 rpm.
The valves will be open for the first two seconds that the car is started. It requires time for the vacuum pressure to build to close the valves. After that The operation of the NPP is normally closed, open on demand. Have someone stand behind the car and bring up the RPM to 3,500 and you should see the valves open. The butterfly operation is tied to the throttle position sensor and the RPM. It uses the throttle position to determine driver intent.
Under normal operation the valves work as follows:
Below 30% throttle and 3,500 rpm the valves are closed
Above 30% throttle and 3,500 rpm the valves will open
Between 30% throttle and 80% throttle and above 3,500 rpm the valves are open
Above 80% throttle and above 2,800 rpm the valves are open
Last edited by FLC6GS; Nov 8, 2018 at 12:51 AM. Reason: Copy/Past posted img jibberish and not the text ??
OP - Don't sweat it, most of us with factory NPP over ride the software and leave the system open ALL THE TIME.
I found the opening and closing of the factory system rather distracting while playing with the throttle when sliding the car around on tight mountain roads, my preferred environment.
That's a very good point about it being distracting. I've just been opening it whenever I feel like and that's been fun enough. I guess I was figuring that the lack of vacuum under heavier throttle would cause the butterflies to open.
Now I just have to figure if the car actually feels faster when it's open.
Seat of the pants meter seems to say 'yes'.
Only works open or closed.
