Coolant return hose Tee fitting
Old Nov 10, 2018 | 01:33 AM
pdc001's Avatar
pdc001
Default Coolant return hose Tee fitting
The plastic oem tee fitting is starting to leak so I'm looking to replace it with a brass or steel tee fitting. Anyone know where I can buy one? What's making it difficult is that it's reducer type fitting.
Old Nov 10, 2018 | 01:52 AM
c6 monkey's Avatar
c6 monkey
Home depot, you may have to piece it together. I did brass
Old Nov 10, 2018 | 09:21 AM
Boosted_Z's Avatar
Boosted_Z
I ordered mine online through eBay easily. 304 Stainless steel . Was 8$ tho..
Spark 2's Avatar
Spark 2
St. Jude Donor '07-'08-'09
There are stainless tees available on Ebay.
You need 3/8" X 3/8" X 1/4"
Good Luck!
Old Nov 10, 2018 | 10:00 AM
Kenny94945's Avatar
Kenny94945
That stainless tee looks like the right replacement part.
Old Nov 10, 2018 | 11:18 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Tee
NAPA has a replacement piece. A little smaller in length but works great.
Old Nov 10, 2018 | 11:31 AM
pdc001's Avatar
pdc001
Good Luck!
Is that ID or OD?
Old Nov 10, 2018 | 12:32 PM
Spark 2's Avatar
Spark 2
OD on the tee
ID in the hose
Old Nov 10, 2018 | 03:48 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
https://www.ebay.com/itm/Corvette-C6...item286b2bdbde
Old Nov 10, 2018 | 04:03 PM
2008 Corvette
$19.99 at the site on eBay or $2.23 at NAPA. One other site eBay 2 for basically $10.00 and they are SS.
Old Nov 11, 2018 | 12:48 AM
Cherokee Nation's Avatar
Cherokee Nation
Ace hardware 3 pieces of brass for about $6 bucks is what i paid four years ago.
Old Nov 11, 2018 | 08:38 AM
PCMusicGuy's Avatar
PCMusicGuy
Also commonly available on Amazon for about $10.
https://www.amazon.com/Joyway-Reduce-Union-Fitting-Intersection/dp/B07HL9NGWV/ref=sr_1_10?ie=UTF8&qid=1541943382&sr=8-10&keywords=brass+hose+tee https://www.amazon.com/Joyway-Reduce-Union-Fitting-Intersection/dp/B07HL9NGWV/ref=sr_1_10?ie=UTF8&qid=1541943382&sr=8-10&keywords=brass+hose+tee
Old Nov 12, 2018 | 11:43 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Plastic?, mine looked like it was made of some kind of compressed/glued cardboard. I gave it to the Maint. guy at work and he put one together for me using Brass fittings. Free......
Old Dec 1, 2018 | 10:29 AM
Shikaitsu's Avatar
Shikaitsu
Can anyone confirm the fitting size on this? I'm having this issue now and I'm reading 3/8 x 3/8 x 1/4 on some threads and 1/2 x 1/2 x 3/8 on others.
Old Dec 1, 2018 | 10:49 AM
2008 Corvette
3/8 by 3/8 by 1/4. eBay Stainless Steel 2 for a little under $10.00. Works great.
Old Jan 23, 2019 | 12:46 PM
719c6's Avatar
719c6
Actually 5 pcs for $9.50 shipped. Item number 331892668702 on the auction site.
Old Mar 16, 2019 | 09:52 PM
sneal46's Avatar
sneal46
Just replaced my tee with a stainless version from Ebay. Took 5 minutes. This is well worth the peace of mind to change out.
To Coolant return hose Tee fitting
Old Mar 16, 2019 | 10:08 PM
linkedge540's Avatar
linkedge540
Just ordered mine from eBay stainless Steel 5.50. Sounds like good preventative maintenance.
Old Mar 17, 2019 | 12:42 PM
captain vette's Avatar
captain vette
really love your avatar!
Old Mar 17, 2019 | 08:20 PM
LS14ME2's Avatar
LS14ME2
Does that fitting come out/off pretty easily without breaking in the hose? And is it necessary to remove the intake hose just above it?
