06 Automatic.. "S" (Sport) Position Won't Work...
It's been working fine for the past 1.5 years or more without a glitch.
Can easily move the shifter from PRNDS. No hitches.. Smooth as glass.
Additionally, I reconnected the battery again. No change.
I also pulled that 2 AMP fuse referenced above... and it's OK. It's physically OK and checks out OK with a continuity tester.
CWIC (11-13-2018)
Interesting. As previously posted, I did have a cable issue, and that cable was replaced completely about 1.5 years ago...
Never considered the possibility that the cable might not be moving the selector enough to go "into" S mode.
Thank you for the links.
Update:
I've got the rear of the car in the air.. on jackstands..
I'm 6'4" and 240# so it's tough for me to wiggle under there. However, tomorrow, I have one of my "thinner" friends coming over. He's about 5' 9" and about 135#... He can wiggle under there easily. He was one of the guys who helped me when the cable broke in my garage about 2 years ago...
I'm gonna put the car into S on the gear selector, and he's gonna see if it is truly "popping" in all the way on the transaxle lever...
I wonder too if there is some micro-switch that turns "ON" when the transaxle selector is in S mode?? I'll find out tomorrow. He's coming over at about 11:00 AM...
Race Car Tech
Update:
There is a selector signal (PPL wire) that goes to the clock spring as well as the PNK wire from the 2A fuse. The TEHC Module Assembly in the automatic transmission is where the selector signal is sent from, so I don't know if it is accessible. If you can find a connector to the transmission, it should have 16 pins. You can check to assure that pin #7 is OK, not bent, and making good contact. That's all I have
Hopefully, it is just the gear selector not fully getting to the "S" mode.
Good luck
No luck.
Had the rear in the air supported on jackstands. My buddy crawled under the car. We went through the gears... PRNDS...without starting the engine.
The trans lever was "popping" all the way back to S.
Started the car...Had the DIC visible in the heads up display.
Nothing came up... no shift indicator... no paddle shift.
My bud (wearing mechanics gloves) tried to "force" the lever back further into the S position... Nothing..........
So...........our experiment failed. It's not the cable..
Looks like I'll be calling my Chevy dealer in the near future.
Received 2,062 Likes
Exactly correct. There is a cable adjustment link at the transmission end. It's a simple plastic clip arrangement that allows about 1/8" of length adjustment per step. I don't remember for sure whether you need more or less length, but I'd try less for starters. Assuming the lights on the console closely match the location of the lever, I'd only move the adjustment one notch before taking a test drive. Otherwise, try two notches.
I'm sure someone here can verify the direction you need to get the length correct. It's been 5-6 years since I did mine and I'm also "old".
I read through my owners manual several times but recently watched this video. Someone recorded the DVD that came with the cars new onto a YouTube video. In the power train section of this video they explain how to get the transmission back into Automatic Shift mode without having to shift it out of Sport mode. I haven't had a chance to try it yet since our car is in winter storage already.
https://www.youtube.com/watch?v=tJWdp2BNOhg&t=1532s
Check this. Read the posts by Dano523 on how to adjust the cable.
#33
I believe the video was for 2010 or later, since it included GS info. IIRC the shifting software was changed in '10 to allow the feature to hold the + and revert to D. Prior years don't have that capability, unless a friendly dealer would do that software upgrade.
#35
2020 C6 of the Year Finalist - Modified
When under the car the transmission lever when pushed towards the rear is PARK. To the front all the way is S. Snap the front on and make sure the shifter indicator in the car is in NEUTRAL, 2 clicks on the transmission from the REAR forward is NEUTRAL Snao on, done.
#37
#38
I replaced my TC this fall and only had 5 positions on the transmission. I also am having some of (only slightly so far) of those memory issues, particularly when the wife is around.
HOXXOH (11-16-2018)
#39
Thank you and I'm going with your most recent results. I've also gone from listening to the wife's version of my memory "problems", to asking her what she remembers. It works as a pre-emptive strike on her recall and gives me the opportunity to agree or dispute.
#40
I'm bringing this back TTT.
Took the car to my local Chevy dealer on Tuesday morning. Just got a call-back this afternoon, Wednesday.
Car is done............ fixed.........
It was the shift cable. They checked it out electrically, and all was OK. Then, the service writer told me that they really BANGED it back into S... and it started to work. They adjusted the cable.
Trans end? Shifter end? I don't know.
Even though myself and a friend tried this, I guess we weren't rough enough. I'm having a few more things done, so I pick the car up tomorrow...
Thanks to all here for your input. This the the THIRD time I've had an issue with that shifter cable. The car has 35,000 miles on it.
#1...it broke last year. Was able to drive the car to the dealer after jacking it up and putting it in D.
#2..it popped off...right after I drove it home from incident #1. The dealer sent a rollback that time, and fixed it again on their dime.
#3.. this current episode..
