E85 Fuel
Old Nov 15, 2018 | 08:52 PM
TucoTom's Avatar
TucoTom
Default E85 Fuel
Why would someone running a Corvette want to use E85 fuel??
I go out of my way to run non-ethanol.
Old Nov 16, 2018 | 11:44 AM
farmington's Avatar
farmington
E85 is much higher octane than pump premium.
Old Nov 16, 2018 | 12:37 PM
dr_gallup's Avatar
dr_gallup
Needs a tune for E85 but if you've got big cams and high compression or boost to take advantage of the octane then it's worthwhile. Many on the internet spread ridiculous ethanol stories but every car made for decades is totally compatible with E10.
Old Nov 16, 2018 | 12:45 PM
truggiero19's Avatar
truggiero19
It burns cooler and cleaner than 93 with a much higher octane rating so you can run more timing safely with cooler IATs. This is great for boosted or high compression motors but will show only minor increases in power with normal naturally aspirated street builds. The only down side to E85 is you need about 30% more E85 to make the same power as 93 so this means an upgraded fuel system to support the demand and a loss of 30% of fuel economy. Unless you have an old or carbed vehicle there is no reason to avoid gas with ethanol.
Old Nov 16, 2018 | 02:50 PM
black00ta's Avatar
black00ta
Because "race fuel" at the pump is a nice thing to have considering the options out there.
Old Nov 16, 2018 | 03:29 PM
TucoTom's Avatar
TucoTom
I just got Educated.
I never would have imagined a race car running ethanol.
Thanks gentleman...I need to research E85.
Old Nov 16, 2018 | 06:29 PM
Smdusaf's Avatar
Smdusaf
Plus it’s usually about $1 cheaper than 93 and I gained 20hp over 93 on my ls3 na motor
Old Nov 17, 2018 | 09:14 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
I'll never use it.
To E85 Fuel
