Ill be doing a diff fluid change soon and Ive read all the many many thread about it. They all say to use the GM Ls Gear Oil which has the friction modifier already in it. I will probably go this route.
However I did also find this thread https://www.corvetteforum.com/forums...id-change.html in which apparently GM again has updated their recommendations; the OP of this thread learned of it from his local dealership. This time they reccomend using GM synth gear oil with an additive. This is the only thread Ive seen that mentions this new TSB. Does anybody have this tsb or know anything about it. The thread is from 2016, and if you read through a member does indeed find the tsb and GMs new recommendation about sy thetic gear oil + additive.
Reason: Spelling
The "new" Synthetic doesn't look like it is for the Corvette.
It does NOT contain the required friction modifier for the LSD, although it could probably be added. And it's grape scented??
Stick with the AC Delco Dexron Part# 88862624.
Yes I already decided I would. Thanks for your quick reply. My question is about the update mentioned in the above thread. The TSB that changes the recommendation to synth+ modifier; does it exist or what? Several members in that thread seemed to confirm it and the OP's local dealership gave him the part no for the synthetic stuff back in 2016. Where can I find that TSB? Is it legit? And if it is legit just wondering why would we ignore this TSB and not the one from 2007 or 2008? Just asking because the general consensus about it on this site seems to have not changed since then.
https://www.corvetteactioncenter.com...6-corvettes/6/
I don't find any TSB regarding a different fluid for C6 differentials after the Dexron LS one. If the "new" one was written in 2016 or anytime thereabouts, it may pertain to the C7's only.
The TSB for Dexron LS was first published 01-09-2008 even though the new fluid had been the factory fill for a few months prior. Best estimates were the change came sometime in Sept or Oct of '07
The only reason the TSB stated to drive 8-10 tight figure 8's to work the fluid into the clutches, was so the customer would not continue to experience the clunk/chatter when leaving the dealership until he/she drove it for a while. i.e. aka instant customer satisfaction.
My '08 came off the line 10-30-07 and already had the Dexron LS. It was changed at 55K miles under warranty (axle seal leaks) and again by me at 98K (no figure 8's). I'm at 154K now and don't plan on another change for at least another 50K if at all. If you already have Dexron LS and you have less than 150K miles, I wouldn't bother changing it until at least then.
i was having the "clunky" sound when turning and going slow. came to the forum and read, and read, and read. There are a few different oils that were recommended but it was strongly suggested that I get the specific GM oil from the dealer , but it was more expensive. I went with Mobil 1 alternative that a few people mentioned to save a few bucks. It made the noise a bit less, but was still there and very annoying. So, i went to the dealer and bought the expensive oil and tried again. Instantly fixed the issue and no problem since. live and learn. As mentioned above "Stick with the AC Delco Dexron Part# 88862624."
No, read your manual. My manual says to use GM additive along with the specified gear lube. In my case, it took two bottles of GM additive, the second bottle only required a couple of ounces. for my case, for a few bucks, it took the click out of the rear end.
some here have a copy of a service bulletin than calls for a new fill and no additives.
I found the AC Delco fluid for 10$ less than the dealer price. Same stock numbers and all.
Amazon
I was going to try that route as well, but I had a road trip planned with my son from Pa. to Deal's Gap two days later and wanted to get the issue resolved ASAP..... so I sucked it up and paid $28 per quart at the local stealer.
Your '08 owner's manual was printed well before the factory changed to the new fluid.
My vette is an 05. Anything it says in the manual would be superseded by the 2008 tsb which reccommends the Dexron LS. I know that part. What I was asking about was if there is updated recommendations via TSB or otherwise. The guys in the thread I mentioned clearly state that their local dealerships gave them different part numbers (synth+additvie) than the Dexron. So you are saying there IS an updated TSB AFTER the 2008 one?
