mirror problems help
Old Dec 15, 2018 | 11:19 AM
teddycarnut's Avatar
teddycarnut
Default mirror problems help
My last thread I didn,t make myself clear enough. My exterior mirrors glass goes down all the time and I must reset each time I start the car, using either FOB. Resetting the fob does not help. Is it a mechanical problem. Any one else experience this. Thanks.
Old Dec 15, 2018 | 12:43 PM
HK770's Avatar
HK770
First off I'm not sure all cars have auto adjust mirrors.
The car came from the dealer with two fobs I and 2 programmed for car.
You can have up to 4 programmed to car.
Only the first two programmed will word system of auto adjust system numbers or not( not matter, just first two.)
Assuming one of the first two proggramed fobs is being used.
YOU need to start the car and adjust everything as you like.
After all, is adjusted you need to decide if your driver 1 or 2 on the door panel.
Choose #1 or #2 button push in till you hear a beep.
Next time you enter car with that fob, get in close door--- push door button for that fob. 1 or 2
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Same r using seat exit (middle button) slide seat to the rear to adjust how far back.
then push middle button till a beep is heard
FOBS MUST BE FIRST TWO PROGRAMMED! else
you how to reprogram them that way
Old Dec 15, 2018 | 02:28 PM
BackInBlack05's Avatar
BackInBlack05
Rtfm?
Old Dec 15, 2018 | 05:17 PM
HK770's Avatar
HK770
Originally Posted by BackInBlack05
Rtfm?
My shorthand did not follow that....lol
Old Dec 15, 2018 | 05:50 PM
teddycarnut
Default mirrors
I know how to set fobs, but they won,t hold the settings for the mirrors. Each time must reset mirrors manually, Yes I have memory system with car, not working.
Old Dec 15, 2018 | 05:54 PM
Dutch08's Avatar
Dutch08
RTFM .... (polite version) ReadTheFrickenManual. I consider myself tech knowledgeable but I still occasionally get caught by some acronyms, google is your friend here - FWIW
Old Dec 15, 2018 | 06:18 PM
fireparamed's Avatar
fireparamed
So did they used to work right and have just recently started to this do ?
Just trying to narrow down if it's a new issue or something you've been experiencing since you bought the car.
Old Dec 16, 2018 | 05:32 AM
teddycarnut
Default mirrors
Its a new issue just started.I know how to set them,but next time I enter the car they face all the way down and need to be reset, The manual won,t tell me why. Does't any member understand my problem.They keeptelling me how to set the memory. It must be mech or electrical. Thanks
Old Dec 16, 2018 | 09:04 AM
EVRose's Avatar
EVRose
Are you using the same fob as you were before this started?
Old Dec 16, 2018 | 11:57 AM
teddycarnut
Default mirrors
Yes same FOB new batteries seats work just mirrors
Old Dec 16, 2018 | 12:30 PM
EVRose's Avatar
EVRose
Read post #12 in this thread.
https://www.corvetteforum.com/forums...post1583438375
Old Dec 16, 2018 | 04:23 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by teddycarnut
...Does't any member understand my problem...
Jeez, don't get all pissy, folks are trying to help by asking what may, to you, seem to be obtuse questions.
Have you checked for codes? Have you checked your settings in the DIC? I can't remember if there is a "park" feature that puts the mirrors all the way down so you can see the ground alongside the car.
Old Dec 17, 2018 | 05:29 PM
HK770's Avatar
HK770
Almost afraid to ask, but you know there is the long and the short .....program for fobs
Short is for #3 and #4 fobs.
Old Dec 17, 2018 | 05:39 PM
449er's Avatar
449er
CF Community Team
I learn something new here every day!
To mirror problems help
