Buba1vette
Old Dec 15, 2018 | 01:35 PM
buba1vette's Avatar
buba1vette
Cruising
Default Buba1vette
I have a 2005 base convertible that I purchased 4 years ago.
Problem, vibration in steering wheel and seat starting at 80 mph and gets worse at higher mph. Over the past 4 yrs the has been road forced by 6 different shops. Just recently had alignment done and put on new Michlin pilot sport 3 +. Rims have been checked for radial and lateral run out all are fine. I’m told the rotors are running true. I checked the rotor temp after a 1 hr ride, no significant difference between them. I’m at my wits end and help figuring this out.
Old Dec 15, 2018 | 06:16 PM
Dutch08's Avatar
Dutch08
OK, you have checked everything so I have no clue. So here's a SWAG ... I would suspect either tires or the castor setting on your alignment. I would go just bit overspec (more) on castor and if that doesn't work check tires and/or worn suspension tie rods etc.
Old Dec 15, 2018 | 06:20 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Bent rear axle, Drive Shaft or torque tube issue, worn rear suspension component.
Old Dec 18, 2018 | 07:20 PM
buba1vette's Avatar
buba1vette
Cruising
Thanks will do
Old Dec 18, 2018 | 08:50 PM
jashmore1234's Avatar
jashmore1234
Put it in the air and see how you can move the steering wheel before a wheel moves. If there is a bunch of slop, you will get the steering wheel shaking at speed.
Old Dec 19, 2018 | 07:31 AM
buba1vette's Avatar
buba1vette
Cruising
the front end shop said they checked the rack, etc. but I will check it your way. Hoe much play is too much?
Old Dec 19, 2018 | 10:47 AM
Sox-Fan's Avatar
Sox-Fan
Check the run out in the bearing/hub units too. They only last just so long.
Old Dec 19, 2018 | 03:20 PM
jrose7004's Avatar
jrose7004
Your thread would get a lot more looks if you would state you subject in the title line and not you screen name.
To Buba1vette
