2007 Vette will not start
Old 12-15-2018, 02:39 PM
shythone
7th Gear
shythone's Avatar
Default 2007 Vette will not start
2007 Corvette will not start. Wife & I took Vette to get gas a couple weeks ago. I went in to pay and when I came back out, wife tried to start car. Would NOT start. She said she could smell something HOT and smelled electrical as I went into station. She also said she saw a puff of smoke come from under the right side of the hood. By the time I returned to car, the smell was gone.
Found someone with booster cables but to no avail. As it is a stick, we then "push started" the car and drove it home.
Would not start afterwards. I bought a new battery installed it and still won't start.
Power comes on, accessory mode works windows, radio, etc. all come on.
Tried START and only get gauge readings and hear click. Had an electrician buddy come out with a voltmeter. He checked all fuses and relays which checked fine. I jacked up Vette, crawled underneath looking for frayed or burnt wires. everything intact. Even the fusible link was good. the anti-theft light is NOT on.
I disconnected "negative" side of battery, left it a few minutes, came back and reconnected it. Same problem.
PLEASE help !!!
Old 12-15-2018, 04:36 PM
rkj427
Pro Mechanic
Support Corvetteforum!
rkj427's Avatar
Received 3,952 Likes on 2,470 Posts
From your description, not clear if it doesn't engage starter motor...………..
if you checked all wiring, did you also check starter motor for functionality...…………….
possible to have power available at the wiring connections, and still have a malfunctioning starter motor...…………...
shythone (12-16-2018)
Old 12-15-2018, 04:41 PM
Lee Cromwell
Lee Cromwell's Avatar
Sounds like the starter to me as well, it's a known issue at the connector
Old 12-15-2018, 04:44 PM
BackInBlack05
BackInBlack05's Avatar
Starter? Battery cables?
Volts by themselves don't mean much. Need volts when current is drawn. Bad connections can show volts until a load is supplied.
Old 12-15-2018, 04:54 PM
WW7
WW7's Avatar
I'm thinking starter solenoid ..Get under it and see if it could be battery wires or a cracked solenoid..Second guess, starter is bad or shorted out....WW
Old 12-15-2018, 05:11 PM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
See if this is cracked or if wires don't look right.
https://www.amazon.com/gp/product/B06X6JF3CL/ref=ox_sc_saved_title_6?smid=A1E2MGYDTPEYH7&psc=1 https://www.amazon.com/gp/product/B06X6JF3CL/ref=ox_sc_saved_title_6?smid=A1E2MGYDTPEYH7&psc=1
Old 12-15-2018, 06:00 PM
Bruze
Bruze's Avatar
Received 1,136 Likes on 882 Posts
Old 12-15-2018, 06:46 PM
Nice Ride
Nice Ride's Avatar
Sorry to hear of the electrical problem. The puff of smoke and electrical smell likely indicate a component failure, and not just a battery. At this point I would take it to a Chevy dealer with certified Corvette tech who can correctly resolve the issue. Good Luck.
Old 12-16-2018, 11:03 AM
shythone
7th Gear
shythone's Avatar
the starter never attempts to engage.
Old 12-16-2018, 11:19 AM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
Check the top of the starter to see if the solenoid has come apart. Happens a lot on cars with headers.
Old 12-16-2018, 11:23 AM
Bruze
Bruze's Avatar
Starting at the beginning: If the starter doesn't do anything, but dash lights come on, then loosen and wiggle both battery terminals, retighten and try. If it doesn't help, get under car and do the same with the other ends of BOTH cables, and visually inspect the solenoid and its terminal. If the car still won't turn over, remove the battery and have it load tested.
However, the puff of smoke also needs to be tracked down and maybe that should come first. What did it smell like? An electrical burn or not?
Old 12-16-2018, 01:26 PM
shythone
7th Gear
shythone's Avatar
She said it smelled like an electrical burn
Old 12-16-2018, 01:34 PM
rkj427
Pro Mechanic
rkj427's Avatar
It could have been an issue with the starter solenoid contacts, or possibly even the armature and brushes of the starter motor itself, which would explain that the starter doesn't even function or try to engage..................
check all the voltages to the starter, and then have the starter motor itself removed and tested
Old 12-29-2018, 09:27 AM
shythone
7th Gear
shythone's Avatar
Default Solved !!!
Problem solved !!!
Contacted local shop which specializes in performance cars and especially GM. He came with a rollback, took it to his shop, replaced starter and called me 3 hours later to get the car.
He said the starter was completely fried. The new starter is very quick and sounds powerful.
Looking back I remember the old starter was lagging and struggled to start. So if your Vette is starting to struggle to start, replace the starter immediately.
THANK YOU to everyone who replied. I really appreciate your comments.
Landru (12-29-2018)
Old 12-29-2018, 11:22 AM
rkj427
Pro Mechanic
rkj427's Avatar
Problem solved !!!
Thank you for responding and letting the forum members know exactly what corrected your issue!
That is how a forum should work, as others may have this concern and now can find resolution.
The following 3 users liked this post by rkj427:
Landru (12-29-2018), Rico7142 (12-29-2018), shythone (12-29-2018)
Old 01-03-2019, 04:04 PM
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
Problem solved !!!
Positive cable connection at the starter motor fried on my ZR1 over a month ago and wouldn't allow the battery to recharge. Engine would not jump start with battery cables either. I am seeing more and more reports of this on C6 cars as time goes by.
Old 01-03-2019, 04:22 PM
RichKiss
RichKiss's Avatar
To 2007 Vette will not start
Old 06-15-2019, 09:05 AM
shythone
7th Gear
shythone's Avatar
Old 06-15-2019, 09:06 AM
shythone
7th Gear
shythone's Avatar
Old 06-15-2019, 12:43 PM
agorena123
agorena123's Avatar
Just replaced my starter this past Friday on my 08 Same symptoms as yours but no electrical smell. It would start sometimes and sometimes not. Battery was on its last legs so replaced it but problem persisted. Starts up strong now. It's cammed, headers and catted x-pipe.
I did not go this route as the car got 64k miles before needing to replace the starter, but a local Corvette modder/tuner recommends using LS3 starter with appropriate wiring modifications as permanent remedy to starter issues common with C6s.
Quick Reply: 2007 Vette will not start
