Debating on engine "looks"
#61
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
What fuel rail kit is that? I like the blue.
Im in the same mode you are.
Just installed my Holley valve covers. Cleaned up all the wires. Moved the big white plug to the back
next will be getting everything painted the way I want.
We have a lot of rain so. Have nothing but time right now.
Installed the new fuel rails today. now I'm just waiting for the Holley valve covers with the coil covers in RED. they are on back order until next month. I'm considering a hydrodip on the intake manifold. I'll see what it looks like once the covers are on. Still needs a good cleaning and I may change the routing of the fuel line..
#63
https://www.ebay.com/itm/Z937-LS2-8A...72.m2749.l2649
#64
hmmmm16417 (01-14-2019)
#65
marinablu67 (01-15-2019)
#66
Cool. Thanks for the info. I didn’t even think about swapping the fuel rails. Seems easy enough.
I’ll be watching your progress
hopefully this is allowed, but here is the link - you have to specify what color rails you want in your payment message. then have red, blue, silver and black. seller is very responsive if you ask questions. used stock injectors and seals, brackets lined up perfectly. the only cons were I had to modify the driver side safety retainer bracket on the rear side and the fuel line seems just a touch short. I ordered a 45 degree fitting that will help with my lenght and angle issue but I'm considering re-routing the fuel line when I put the valve covers on.
#67
#68
Received 1,136 Likes
When I got my C6 in 2014 I took a gearhead buddy for a ride; he was 74-75 at the time (has since died). After we got back I popped the hood, he laughed and admitted he had no clue what he was looking at.
#69
Wish I could have kept my C2 and the C6.
