Starter Problems??
Old Jan 3, 2019 | 12:47 PM
Chase0808's Avatar
Chase0808
Default Starter Problems??
I've recently run into the problem of not being able to start my 09 A6. The fob is recognized and when I press the start button, I hear a single click(sounds like its coming from the starter) but no start. The dash will then light up as if the car has been started but I can't even get it to try to turn over. I tried a new battery and still am having the same result. Im thinking its time to pull the starter and possible replace it or even the solenoid. I hear that I may need to remove the passenger side catalytic converter to do this. Is this all I will need to do?
Old Jan 3, 2019 | 03:51 PM
GOLD72's Avatar
GOLD72
Good chance that the positive cable connection at the starter may have gotten fried which will mean replacement of the starter. Happened with my ZR1 a month or more ago. The bad starter connection would not allow my battery to recharge. Covered by my GMPP extended warranty. Dealer said that the right side exhaust had to be removed to R/R the starter on my ZR1 so might be the case with your A6 as well.
Old Jan 3, 2019 | 06:00 PM
Chase0808's Avatar
Chase0808
Just got the starter off and found the problem. Solenoid boot was completely broken off. I was also able to get the starter out without having to remove or loosen the passenger side cats. Hopefully it’s just as easy to get the new starter back in. I’ll update when done
Old Jan 3, 2019 | 06:03 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
recently replaced my starter as the solenoid had melted due to headers.
Old Jan 3, 2019 | 06:05 PM
Chase0808's Avatar
Chase0808
Any tips on getting it back in? I’m not looking forward to fighting the new one back in place
Old Jan 4, 2019 | 09:14 PM
mcandrew67's Avatar
mcandrew67
unbolted headers from engine and pushed to side. I have long tube headers with hi flow cats. That gave enough room
To Starter Problems??
