Third tail light bolt
Old Jan 23, 2019 | 12:46 PM
Brenda1's Avatar
Brenda1
Default Third tail light bolt
I am going to install my new ZR1 type spoiler tomorrow. I watched the instructional video and fell ready for the challenge. One question not addressed by the vidao, what is the bolt size for the third tail lights. I am guessing 10mm but want to be sure. You can't see it and I would hate to strip it with a close but wrong socket. Thanks, will be posting photo's soon!
Old Jan 23, 2019 | 01:17 PM
wayback's Avatar
wayback
10 mil is correct. Make sure not to over tighten the bolts on the spoiler......your only going thru plastic.
Old Jan 23, 2019 | 01:25 PM
jbc1995fb's Avatar
jbc1995fb
I recently replaced my factory GS duck bill spoiler and its 10mm. Check the size of the bolts/nuts/washer on the new spoiler. Mine was 11mm so I couldn't use the factory bolt/nut assembly which was not big deal.
Old Jan 23, 2019 | 02:49 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Read it again. Does not ask for spoiler bolt size. Asks for third tail light bolt size which has to be swapped from old to new spoiler. Easily done with spoiler off. 7 mm or less.
Old Jan 23, 2019 | 03:17 PM
Brenda1's Avatar
Brenda1
Sorry for the confusion. The bolts that attach to the studs on the under side of the factory black wicker bill type spoiler. After removing the 4 round tail lights, I will need to take off the third tail light, what would be the right deep dish socket for removal.
Old Jan 23, 2019 | 03:24 PM
jbc1995fb's Avatar
jbc1995fb
10mm deep socket.
Old Jan 23, 2019 | 03:49 PM
2006ls2's Avatar
2006ls2
Default Tail light bolt
10mm deep socket is correct, just finished doing a spoiler switch. As mentioned not too tight.
Old Jan 23, 2019 | 04:25 PM
2008 Corvette
Suggestion. Tape off around the edge of your OEM spoiler on the body of your car while you take off the old one. Unplugging the 3rd brake light is not always the easiest while the spoiler is loose. Take your time..
Old Jan 23, 2019 | 07:54 PM
Brenda1's Avatar
Brenda1
Great advise that this one is why I always check here before doing tasks on my car, even not too complicated jobs like this one. My car and my paint thank you for your suggestion!!!!!!!!
Old Jan 28, 2019 | 07:50 AM
Andysherman's Avatar
Andysherman
You also will probably need to remove about 1/16" of material from the front of the rectangular opening where the 3rd brake light connector goes... needs just a hair more clearance for the edge of the connector & wires to go through. You'll see what I mean when you do a dry fitment on the new spoiler... a flat file will do...
Old Jan 28, 2019 | 10:13 AM
SixAddict's Avatar
SixAddict
When I installed mine, I went with fender washers as I did not like the ones that came with the ZR1 spoiler. Also wrapped my tail lights in old micro fiber towels as they hung down on paint at bumper. This part may have been in the video, it's been a while since install. Good luck.
Old Jan 28, 2019 | 11:47 AM
2008 Corvette
This is excellent advice. Thanks. Also remove bulb socket from light housing by twisting it out. Eliminates lights from hanging on bumper even though wrapped. Also excellent advice from other poster.
To Third tail light bolt
