Wiper Blade Replacement
Old Jan 26, 2019 | 07:21 PM
Ed Cackowski's Avatar
Ed Cackowski
Default Wiper Blade Replacement
Hi Rocket Riders !!!
I noticed the rubber portion of the windshield wipers on my 2013 427 vert needed replacement. Stopped by my local Advanced auto parts store and picked up a set of 21 inch replacements per their computer. When I tried to install them I noticed that there is a difference between the stock drivers side and the passenger side wiper blades. Most dominant difference is the support arm that runs parallel to the blade on the drivers side wiper. The replacement parts section of the owners manual a has two part numbers 12335960 for the Driver side and 1235961 for the passenger side ., I also noticed the passenger side wiper does not lift off perpendicular to the windshield like the Drivers side does .
I need help from the vast Corvette knowledge base with the following, (1) am I wasting time with Advance Auto parts replacements (2) is there a special purpose for the support bar that is installed parallel to the drivers side blade and (3) is there a trick to lifting the passenger side wiper parallel to the windshield ?
Thanks I appreciate any help
Old Jan 26, 2019 | 07:28 PM
gsflyer2011's Avatar
gsflyer2011
Yep, complete wiper replacements at the GM parts were something like $17. 00. OEM, took 3 minutes to put the new ones in. Very cheap.
Old Jan 26, 2019 | 08:07 PM
Ed Cackowski
Thanks GS Flyer I will go to the dealership any trick to replacing the passengerside as it doesn't lift off the windshield ?
Old Jan 26, 2019 | 08:43 PM
GUM3Y's Avatar
GUM3Y
I bought the Bosch Icon replacements at my local Advance Auto based on recommendations from various forum members. They fit great, work great, and look great. No complaints whatsoever and they have a silicone blade. The driver side doesn’t flip up like the passenger side but I was able to replace them just picking the arm up a few inches.
Old Jan 26, 2019 | 09:14 PM
gsflyer2011
You should be able to slide it out just by lifting the arm a inch or two. ( as far as it will lift) It is designed to be replaced that way, slides out differently than the driver side because of the reduced space. Like you i had few minutes of head scratching moments but look closely you will figure it out. Once you do it it is easy.
Old Jan 26, 2019 | 09:16 PM
jbc1995fb's Avatar
jbc1995fb
I didn’t know corvettes even had wipers because everyone knows you aren’t supposed to drive them in the rain. Lol. Jk
i like using Rainex on my vehicles,it almost makes having wipers a moot point.
Old Jan 26, 2019 | 09:25 PM
Welker1's Avatar
Welker1
I picked up the same ones at my local AutoZone and agree, they are the same size as the OEM, fit great and, IMO, work better then the OEM, no streaks whatsoever
Old Jan 26, 2019 | 10:20 PM
GUM3Y's Avatar
GUM3Y
Definitely can’t go wrong with these!
Old Jan 27, 2019 | 09:11 AM
tsmart's Avatar
tsmart
I used the bosch icon, and could not figure how to get passenger side off. First, i read i need 21a and 21b. Bad info. They take the same blade, and tho you cant lift up the pass side, I found they both come off exactly the same way. Havent used in rain yet but they look very good.
Old Jan 27, 2019 | 09:16 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I just bought OEM set from Amazon with correct wiper for drivers side, each side was $10.00, with free shipping and no tax.
Old Jan 27, 2019 | 10:33 AM
windyC6's Avatar
windyC6
I'm still waiting for some kind of explanation on why GM designed the pass. arm so it doesn't lift up more than a few inches......any takers ??
Old Jan 27, 2019 | 11:57 AM
Vet Interested's Avatar
Vet Interested
Does it really matter?
Old Jan 27, 2019 | 05:21 PM
windyC6's Avatar
windyC6
Well absolutely it matters. Sometimes it's nice to know why GM does some of the "Interesting" things that they do. It could be nice to know that there is actually some constructive reason for such a blunder......
Old Jan 27, 2019 | 06:01 PM
Vette_DD's Avatar
Vette_DD
Here's why.
https://www.corvetteforum.com/forums...post1565934029
As has been indicated the design is as you see. The drivers side arm will bend at the hinge. The passenger side not. If you look at the action of the wiper and their place on the windshield the stroke of the wipers is from the center towards the drivers side.
With that in mind, putting a hinge on the drivers side gives the owner an easier method for changing the wiper which when off, is resting in the center of the windshield. The passenger side does not need such an advantage as when it is at rest it is positioned closer to the side of the car at the base of the passenger side. Meaning, you can access the blade to change it fairly easily from the passenger side but if you have to change the drivers side blade you will need to lay across the hood to reach it. The bend lets you put it up in to a position to do this a little bit easier.
Old Jan 28, 2019 | 10:55 AM
windyC6's Avatar
windyC6
Originally Posted by Vette_DD
Yea....i've read that one before. But thats still a flip-flop. It's not just about ease of changing blades. It's easier to clean the glass....etc....etc. Why couldn't they just make that darn thing right !!!!......
Old Jan 28, 2019 | 11:52 AM
dr_gallup's Avatar
dr_gallup
Same here and the drivers side has the little wing on it. None of the aftermarket ones have the wing. Sooo important.
Old Jan 28, 2019 | 11:31 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Open the hood!
To Wiper Blade Replacement
Old Jan 29, 2019 | 12:15 AM
Vette_DD's Avatar
Vette_DD
Old Jan 29, 2019 | 10:43 AM
windyC6's Avatar
windyC6
Originally Posted by K-Spaz
Open the hood!
Oh my !!!!! You mean if you open the hood it will allow the arm to lift up ?? WOW !! Wished I would have known that sooner !!............
Old Jan 29, 2019 | 10:48 AM
windyC6's Avatar
windyC6
YUP.....I sound almost as bad as some of the "Powers that be" (or used to be) in here.....
