Drivers seat memory position intermittent
Has anyone else experienced an intermittent problem with the seat not returning to the proper place when you enter the car and start it? The seat egress works fine and it rolls back when I shut the car off, but sometimes when I get into it and start it, it doesn't automatically return to its previous position, but other times it works just fine. I can't seem to finger the problem. The body control module and the seat modules have been previously replaced under warranty to try to fix this gremlin, but the problem still remains.
So I guess I'm the lone wolf here. Now I'm wondering if maybe this could be caused by the battery voltage dropping when the car is parked and the seat circuit loosing its memory. My only other thought is that I saw another post where someone had connector issues with the BCM where the passenger floor was pushing on the connector. I may need to check that out.
I had a problem with the drivers seat intermittently either not moving or moving to a random position on my 2008 coupe (the steering wheel column would also fail to extend on occasion seemingly independent of the seat problem) . I had GMPP, so I took it to the dealer and they replaced the computer box that controlled memory functions. Both the seat & steering wheel have worked flawlessly since. You didn't mention a problem with the steering wheel, so you may have a different source......
Enjoy,
akriggm
Enjoy,
akriggm
Occasionally, when I get in the car and push my button (driver 2), the seat will move up but then stop short. If I use the button on the side of the seat and move it slightly forward and push the "2" button again, it will move the rest of the way into it's correct position.
Other times, it works fine.
I haven't bothered to investigate it.
I have found that lately when my wife drives the car with her fob, the next time I start up the car with my fob the seats and steering wheel don't move to either her settings or mine. Shutting down the engine and restarting solves the problem.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
My 2008 has the same problem since around 2009 and it has been to the dealer 5 times to replace the seat frame because the 3 motors are part of the rack.....Bottom line, it still was not fixed so I turned off the 'Auto Memory' in the options menu and now it stays where i like it.
Mine is also a 2008. I'm starting to think maybe it is related to the battery voltage. It seems like if I keep the car on a battery tender, it doesn't happen. I'm wondering if the battery voltage is dropping too low when cranking the engine over and causing the memory circuit to act up. I'll keep testing, but so far it hasn't repeated when I keep the battery maintainer connected to the car.
