C6 vs. C5 Reliability ?
Old Feb 22, 2019 | 02:53 PM
downsize's Avatar
downsize
2nd Gear
Default C6 vs. C5 Reliability ?
Hello,
I'm a new want a be Vette owner and the C5 and C6 are in my budget. say with 30/40 k miles. Which one is more problem free and has the more reliable motor etc.? I like the looks of both, but not as fond of the pop up lights on the C5, which I would think can become a problem not working right...
Thnaks for any basic info.
Old Feb 22, 2019 | 03:01 PM
fourth vette's Avatar
fourth vette
Default C6 is better
I have had far fewer problems with my C6 than I had with my C5. Plus more horsepower. Both cars were tuned.
Old Feb 22, 2019 | 03:11 PM
SilverC54me's Avatar
SilverC54me
Both are very reliable. I have both and the major issues with either are pretty much the same. Harmonic balancer and battery issues.
My C5 has 177k on it and the C6 has 61k.
Only work on the C5 that would not be considered normal maintenance is the front and rear main seals were replaced along with the balancer. Did have to replace the EBCM at around 40k and did both rear wheel bearings.
So far have not had to put anything into the C6 other than gas, tires and oil.
I do most all my own work on both.
Now don't ask what was spent on personalizing and upgrades.
For you, drive both and see which fits you better. As some others have said in these kinds of threads, don't worry about the miles on the car worry about the maintenance documentation. If it is clean and serviced regularly I would not hesitate to buy a 150k mile car and drive it.
Gary
Old Feb 22, 2019 | 03:14 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum!
I have had both models, actually on my second C6.
Similar chassis, upgraded power train in the C6, and both models very reliable.
Unless you find a C5 Z06 that is a "must have" then I would recommend a C6 over the C5 all day long for the increased power, and updated interior.
Old Feb 22, 2019 | 03:37 PM
downsize's Avatar
downsize
2nd Gear
Hey Gary, Thanks a lot for the info. I'm not much into doing heavy duty mechanical work on my own, so this is why I have asked. I don't want to many problems. I know nothing yet as far as the upgrades etc... Looking for a stock Corvette first. What the hell is a Harmonic balancer? I though that was the instrument you blow into with the Blues band !?
Old Feb 22, 2019 | 03:52 PM
GrandSportRob's Avatar
GrandSportRob
I’ve had both. A 99 C5 for 9 1/2 years and my current 13 Grand Sport for almost 6.. If your budget can afford it go for a late model C6.. The LS3 has 430HP vs 345 for the C5’s LS1. I only sold my C5 since I love the widebody C6 GS and bought it new in 2013.. Zero issues since new. I’d say look for at least at 2010 C6 since it had a lot of improvements over the early years.
Old Feb 22, 2019 | 04:01 PM
SilverC54me
The harmonic balancer is the main crank pulley on the engine. The design of it does have a tendency to fail. This part is essentially the same from 1997 through 2013 for the C5 and C6. All LS1, LS6, LS2, LS3 and LS7 engines are susceptible to this failure.
Gary
Old Feb 22, 2019 | 05:41 PM
BadAV's Avatar
BadAV
Buy a C6. Replacement parts availability is becoming an issue for selected C5 parts.
Old Feb 22, 2019 | 06:39 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree. Both great cars. I've had a few of each. The problem with the C5 is a lack of parts support, particularly the early cars. The C6 is a better car in every way.
Old Feb 22, 2019 | 07:24 PM
FAUEE's Avatar
FAUEE
C5 headlight motors can wear out, c6 headlights craze up and leak... kinda a tradeoff.
If my max budget was low to mid 20s, I would get a c5 and save the money for upgrades and repairs.
Old Feb 24, 2019 | 07:35 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
As mentioned above it's the main crank pulley. The problem is it is a very heavy solid steel two piece item bonded together with molten rubber. The idea is to take up the shock of cylinders firing and smooth out the engine. As horsepower increases it is subjected to more and more abuse and they are a rare item. They are not expensive but they are very difficult to get to and install. Basically every car on the road has them but it's in the higher horsepower engines that they are prone to failure.
I tend to agree on the C6 recommendation. But that's more about the car than it is about reliability. They are however newer, that's guaranteed.
Old Feb 24, 2019 | 07:54 AM
SouthBaySurfer's Avatar
SouthBaySurfer
C6. My '08 has been extremely reliable and relatively trouble-free for 40,000 miles. Have you asked this question on the C5 section of the forum?
Old Feb 24, 2019 | 12:56 PM
baileysade's Avatar
baileysade
C6 definitely an upgrade over the C5 . Like the increased HP on my '08 with the LS-3 plus the six speed tranny. I had to replace the electronic door release modules & right rear wheel hub assembly on the '08 but other than that love the enhancements with the C-6.
Old Feb 24, 2019 | 01:06 PM
ShagVette's Avatar
ShagVette
You can get opinions from the forum, however you really need to drive not one but at least 2 of each generation and see what feels better to you.
This is the C6 section, so most will say C6 is better. Post this in the C5 section, and it will probably be the other way...
Old Feb 24, 2019 | 01:41 PM
Spaceme1117's Avatar
Spaceme1117
I have had both; a 2002 C5 Z06 and currently own a 2011 C6 Grand Sport. They are both very very reliable.
The C6 has more updated styling and has the LS3 which is a great engine. C6 is also a bit more refined and comfortable to drive.
C5Z also has a great engine; the LS6. Styling is late 90's so a bit dated. Feels a bit more raw and visceral which some people like.
Both are great cars.
Old Feb 25, 2019 | 09:02 PM
88redconvert's Avatar
88redconvert
I had a low mileage C5 and now have a low mileage C6. I never had any problems with either one in over 7 years. The C6 is more comfortable and quieter. It seems to be a better car and obviously cost more.
Old Feb 25, 2019 | 09:29 PM
saplumr's Avatar
saplumr
Every generation is better through progression. Personally I wouldn’t consider a c5 over a C6. I’m a C6 guy but the C7 is a more advanced car.
To C6 vs. C5 Reliability ?
Old Feb 26, 2019 | 05:18 PM
Nice Ride's Avatar
Nice Ride
Car for car I favor the C6 over C5. Chevy improves these cars every year so naturally C6 is more refined. That is not to say I would recommend a heavy used C6 over a pristine C5. Condition, miles, service history, car fax and who owned the car are key factors to consider. I would look for a stock Corvette. Stay away from Corvettes that have been modded unless you know who did the work and you are handy enough to deal with non-stock parts and issues. Most Chevy dealers will not work on heavy modded cars if that matters. Good luck.
Old Feb 26, 2019 | 05:56 PM
Vette_DD's Avatar
Vette_DD
Just remember that the newest a C5 can be is 15 years old. The newest a C6 can be is 6 years old.
Old Feb 27, 2019 | 01:52 PM
c05v3tt3's Avatar
c05v3tt3
Gary
Would this also be true of the LS9 in the C6 ZR1? Thanks!
