Small but annoying problem
Old Feb 23, 2019 | 08:35 PM
Lonestar13's Avatar
Lonestar13
Default Small but annoying problem
The plastic cowls around the DIC tend to rattle on my '13 GS. The only thing I found that would actually stop the rattle is sliding a business card between the dash and the DIC cowl. Any suggestions?
Old Feb 23, 2019 | 08:47 PM
airmed2's Avatar
airmed2
If you have any weather strip handy, just pinch off a small piece and stuff it between the seams so that it's not visible.
Old Feb 23, 2019 | 08:50 PM
Bob Paris's Avatar
Bob Paris
Or a TINY black rubber o-ring
Old Feb 23, 2019 | 08:58 PM
Bruze's Avatar
Bruze
A little dab of clear silicone.
Old Feb 24, 2019 | 08:40 AM
WW7's Avatar
WW7
Duct Tape...... Ok, I guess you could use electrical tape.. Sounds like your bezel isn't being pulled up tight enough for a solid fit against the dash. Put a piece of tape (or two) on the back of the slot/hole where the prong on the bezel snaps into, this will pull the bezel in tighter against the cluster and stop the rattle....WW
Old Feb 24, 2019 | 10:17 AM
cmonkey713's Avatar
cmonkey713
Sounds like one of the clips is not engaged or broken. Take the bezel off and take a look. When it is off you can pad where it contacts the instrument cowel, Take several small pieces of black felt and glue them on the bezel in various contact points and reinstall the bezel It should take you maybe half an hour.
Old Feb 24, 2019 | 10:37 AM
windyC6's Avatar
windyC6
YUP.....this is one of those situations where some good ol garage J-riggun comes in handy.
Old Feb 24, 2019 | 01:43 PM
Spaceme1117's Avatar
Spaceme1117
For rattle of plactic trim, I like to use the loop side of some adhesive backed Velcro strips to place in between the parts rattling. Works pretty good.
Old Feb 25, 2019 | 08:21 PM
ontime's Avatar
ontime
self adhesive felt works well also I bought a 12inch square in the craft section at Walmart and have used it in several cars
To Small but annoying problem
