Oil inside intake with separator
Old Mar 3, 2019 | 10:07 PM
Beef97's Avatar
Beef97
Default Oil inside intake with separator
Was removing my intake last night (getting rod mod done) and noticed that I still have oil inside the intake. I do have a good oil separator installed in between the valley cover and the intake manifold (what I've seen referred to as the dirty side). My question is what is the other hole used for? It's to the right of the pcv entrance. While I do have quite a bit of experience using oil separators on engines, my GS has a dry sump LS3 and not exactly sure how this plays into the equation. I do know there are several lines coming off of the sump tank and oil might be coming from there? Looking inside the hose running from the separator into the manifold, I can't see much of any oil at all and I do know that I have to empty a small amount of oil out of the separator from time to time so I know it's working. Any ideas where the oil could be coming from? It doesn't seem to be from the line before the throttle body because the TB is very clean on both front and back. I have heard of people running dual catch cans and not sure if I need one. I've also read something about dry sump owners running about half quart low on oil to prevent oil from being sucked up into one of these lines? Any advice or suggestions would be great, thanks everyone!
Old Mar 5, 2019 | 12:02 AM
Beef97's Avatar
Beef97
Anyone know what the second port (opposite from pcv) is used for? Looks like that’s where the oil might be coming from
Old Mar 5, 2019 | 12:18 AM
Raptor_WS6's Avatar
Raptor_WS6
Thats evap i believe
Old Mar 5, 2019 | 12:49 AM
Beef97's Avatar
Beef97
i think you are right. Don’t think any oil could be coming from there. Thanks
Old Mar 5, 2019 | 12:42 PM
captain vette's Avatar
captain vette
Beef97 i am confuse here, by oil separator do you mean a catch can.Sorry for my ignorance.thank you.
Old Mar 5, 2019 | 10:52 PM
Beef97's Avatar
Beef97
yeah sorry it's the same thing. It's a Bob's Machine oil separator which is the same thing as a catch can.
To Oil inside intake with separator
