Oh crap...Harmonic Balancer Failure!!
Old Mar 7, 2019 | 01:08 PM
Chevyrelic's Avatar
Chevyrelic
Default Oh crap...Harmonic Balancer Failure!!
As the title says...I believe my HB has failed. This part was replaced last year as a precaution after buying my vette. I had it replaced by "The" most highly recommended shop it town. This sucker didn't even last a year...it failed in my garage (thankfully) at 1,981 miles.It made a racket at start up this morning...btw the ac belt was thrown off the pulley when it happened. I have contacted the shop to discus repairs. I will keep you posted. But for now...what are your thoughts on how to proceed?? Thanks.
Old Mar 7, 2019 | 01:34 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Hard to tell by the photo you posted, but if your shop installed an OEM balancer, that's where the mistake was made.
Old Mar 7, 2019 | 01:40 PM
Turbo6TA's Avatar
Turbo6TA
Next balancer you purchase should be this ...
It won't fail like the one you had installed a short time ago:
Powerbond Race Performance Harmonic Balancer
P/N: PB1117SS
https://www.summitracing.com/parts/p...model/corvette
_______________________________
Another option is an ATI balancer ... Excellent, but costs twice as much as the Powerbond
Old Mar 7, 2019 | 01:43 PM
Chevyrelic's Avatar
Chevyrelic
They told me it was an aftermarket HB that they had had great luck with when installed. I do not remember the brand.
Old Mar 7, 2019 | 02:24 PM
jaredtxrx's Avatar
jaredtxrx
It looks like an after market 8-rib balancer. Maybe even a Power Bond.
It could be that the balancer didn't fail but the installation wasn't done correctly.
Old Mar 7, 2019 | 02:25 PM
cgladish's Avatar
cgladish
can't tell from the picture, but did it actually fail, or just come loose?
either way, your shop should be on the hook for this repair.
fingers crossed with me, I just replaced my HB a few weeks ago ( power bond ).
original lasted 145k miles. luckily it gave me a warning first ( chirping ).
Old Mar 7, 2019 | 03:09 PM
captain vette's Avatar
captain vette
Turbo 6TA i am a newcomer on the C6 world. What's the issue with that part my '11 GS have about 30k should i be worried?
Old Mar 7, 2019 | 03:32 PM
Trebor's Avatar
Trebor
I agree. GM or OEM HB should last at least 50K miles. My GM factory HB started chipping and caused me to watch it as the engine was running. I then saw the wobble. Car had 45,000 on it at the time.
Old Mar 7, 2019 | 03:36 PM
Vet Interested's Avatar
Vet Interested
Thats encouraging. I have 51,000 miles on mine.
Old Mar 7, 2019 | 03:39 PM
torquetube's Avatar
torquetube
Your crank pulley is definitely several inches forward of where it belongs. Did it actually fail (i.e. separate from the hub) or did the entire balancer just fall off?
If it fell off, that suggests an installation error.
Old Mar 7, 2019 | 03:50 PM
FWC's Avatar
FWC
St. Jude Donor '13, '15-'16,'18 thru '25
Not for nothing but it wouldn't hurt to call the shop and ask about a warranty at least on parts.
Last year I got a throttle body from my Chevy dealer and it crapped out 6 months later, the dealer said the part had a 1 year warranty.
Just last week I had a caliper on my dd go bad, it too had a 1 year warranty. Pads and caliper were replaced for free, labor was not included.
Old Mar 7, 2019 | 04:03 PM
Icecap's Avatar
Icecap
The failure of a brand new part in such a short period certainly indicates a factor other than wear or a suspect design flaw.
Old Mar 7, 2019 | 04:15 PM
cgladish's Avatar
cgladish
at 50k miles, I feel blessed. I got almost 3x that. I'm sure that the HB is on stock LS3's, are the same as the head issue on LS7's.
you know their going to go at some time. so the question is when do you decide to bite the bullet?
not sure about the LS7 head issue, as far as any warning signs. as I mentioned above, my HB started its demise with a chirping noise.
I've heard though, if you're still running a stock LS3, replacing the HB with a Power Bond or ATI, you should expect any long term issues.
Old Mar 7, 2019 | 04:40 PM
EVRose's Avatar
EVRose
I'm betting the bolt came loose and fell out. Possibly from mechanic reusing the old bolt.
Old Mar 7, 2019 | 04:45 PM
Chevyrelic's Avatar
Chevyrelic
FWIW...it is a six groove pulley and belt. The pulley sheared off and the hub is still bolted to the crank. Initial word from the shop was that the part is warranted for 12 months and the labor for three. The fact that this “new” part failed so soon (< 2,000 miles) just irks me...I hope they realize that it shouldn’t have happened and agree to some compromise on the labor for repairs. I believe they have an opportunity here to do the right thing. Either way, I’ll post when I here back from them. Thanks for listening...
Old Mar 7, 2019 | 04:53 PM
torquetube's Avatar
torquetube
If the pulley sheared off the hub, it's a legit (and not too uncommon) parts failure, not an installation error.
A break on labor would be nice, but I don't think you're owed one.
Old Mar 7, 2019 | 07:06 PM
RoadkingC6's Avatar
RoadkingC6
Should last the life of the motor, My balancer didn't make it past 35k miles
To Oh crap...Harmonic Balancer Failure!!
Old Mar 7, 2019 | 07:26 PM
Bob Paris's Avatar
Bob Paris
Don't worry. While there has been a pattern of HB failures noted on this board, yours will probably be OK. If it fails, it fails. Forget about the nervous Nellies on the Forum that DREAD this and that. Enjoy!
Old Mar 7, 2019 | 11:18 PM
buckmeister2's Avatar
buckmeister2
In most states, all shop repairs are backed by warranty for one year. check into it. and let us know.
Old Mar 8, 2019 | 08:51 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Good to hear the hub is still attached. The upside to that is you don't have crank or seal damage to deal with, or at least should not have. Maybe a few scratches on the front cover if it went forward first but that should be all.
If they chose the part, I'd say the least they could do is meet somewhere in the middle. There's lots of variables here, was the OP trying to hold down the price and accepted a $50 balancer? That's not disclosed. It sucks this happened for both parties, but the truth is the shop now has experience on these (assuming they didn't before) and it really should be a slam dunk. If I had a lift and one person to help when reinstalling the rack, I'd bet I could do one of these in 2 hours, easily. Probably with room for coffee in there.
