How do I turn on & off accessory mode on a c6
How would I turn on accessory mode and how would I turn it off it’s a 2011 c6 corvette automatic and it does not have the stock radio it has a double din touchscreen
Received 19,309 Likes
'20-'21-'22-'23-'24
Moved to C6 General.
Press the bottom of the rocker start switch (on). Press the bottom of the rocker start switch(off)
It should also time out in ~20 minutes, then give you ~10 minutes more of RAP before powering down unless you open a door after you exit ACC , at which point it should power down.
Don't hold the bottom of the rocker switch or it will enter service only mode which will NOT time out and you will be left with a dead battery. Make sure when exiting the car there is nothing displaying on the dash or radio.
