Acceleration economy
Cruising
Assuming I wont hit a stop light again for an arbitrary distance, is it more economic to accelerate with as little rev as possible or should I try to get to low end of a higher gear more quickly?
I don't know but I remember reading years ago in Road & Track: Floor it to max torque rpm and shift quickly (max throttle but low revs). Again, I can't verify. IIRC that was a test done by BMW back in the '70s.
But the real way to increase gas mileage is to use as little brakes as possible. Coasting and cornering. Keep momentum.
Received 2,683 Likes
2018 C6 of Year Finalist
Hammer down. All the time.
Considering you can pretty much start off in 4th gear, I think you can get to higher gears very quickly and that's the best way to keep revs down and i.prove fuel econonyy.
Received 2,093 Likes
Buy a Prius...
airmed2 (03-16-2019)
X amount of fuel is used every time your engine revolves. For every 2 revs, 6.2L of air:fuel mix goes in with a nominal mix ratio of 14.7:1. If the engine revolves less for the same distance, it uses less fuel. It's pretty simple math really.
Some of us really dgas about how much it uses. I'd like to think I'm the cheapest sob on the forum and yet I still don't care, other than the entertainment value of keeping the mileage as high as I can make it. If I want to stand on the throttle, I stand on it.
As an example, take an average fuel injected car, with only the driver in it, and drive a steady speed (RPM) on a given piece of road. Measure or monitor the cars fuel economy for that run.
Now take the same car, on the same road, at the same RPM, but fill it with passengers, and hook on a trailer. The fuel economy will decrease, because the engine is under a greater load, and the pulse width will be increased.
Actually, the math is not quite that simple. The fuel injectors are controlled by pulse width modulation, meaning, the computer can vary the amount of time each injector opens at any given RPM. The injectors pulse width is determined by engine load.
I would anticipate that load levels will be relatively low anytime he is looking to increase fuel economy.
That said, if all else is equal, regardless of the load in most situations, less RPMs per distance traveled will result in the best fuel economy.
"That said, if all else is equal, regardless of the load in most situations, less RPMs per distance traveled will result in the best fuel economy."
With respect sir, I agree with you that my example had nothing to do with the OP's question. I was not talking about a Corvette, hence the clarification, "take an average fuel injected car". I merely was pointing out that your blanket statement about fuel and RPM isn't accurate. Load is a HUGE factor in fuel economy. Anyone who has watched a vacuum gauge fluctuate with slight changes in load, like going up a hill will understand that.
The fact is, at any given RPM, an engine will use more fuel if it is under a greater load. As the load increases, the throttle must open farther to maintain the same RPM. Otherwise, you are completely eliminating the volumetric efficiency part of the equation, which is a large part of any engines fuel economy. Certainly a slower turning engine could use less fuel, unless it does not have the horsepower at that RPM to handle the load, in which case the throttle is opened to maintain the RPM, and fuel economy decreases.
I'm not trying to convince you to change your beliefs, I'm only trying to point out the error in what you termed "pretty simple math". It's okay if you disagree with me. I would agree with you, but then we'd both be wrong.
I think if you add a vacuum gauge and do what ever it takes to keep a high vacuum you get the best mileage - does not matter when you shift but dont ride the clutch,
keep on suckin!
keep on suckin!
Received 1,675 Likes
I really wouldn't worry about it!
Received 1,136 Likes
To the OP: For best mileage -- always drive downhill.
if your goal is to save gas, the less the engine rev's the better. But as many says i really dont care.
He thnks the trick to these discussions is to move the goalposts and then claim you're correct. It's easier to read something the way you want to read instead of simply understanding the basic premise. That way you can argue.
In a discussion about efficiency, and after a statement like, all else being equal, somehow the reasoning becomes: No,no Spazzy, that's not true. If I have one car doing vastly more work then the other, with more load on it, I will have to hit the throttle and it will allow more fuel air mixture into the engine at the same speed because there will be less vacuum. Look at what a genius I am, we now have two completely separate situations and I've compared them such that you're wrong! No sense comparing doing the exact same thing as is the very basic tenets of efficiency.
Next thing you know he will think up some other situation that virtually never occurs and expound upon that for a while. I can't wait to hear how when you've reached the limit of power production of the engine and are forced to downshift, now generating more power, that somehow enters into this discussion in a way contrary to what I said.
While accelerating it's best to use more throttle and lower RPM and of course top gear during steady state. The brakes are the biggest gas waster, turns all the nice kinetic energy into heat. But unless you're AOC pushing the Green New Deal, who cares while driving a Corvette? And if you do care, get a Leaf.
