So....
Old Mar 16, 2019 | 09:31 PM
Vette9c6's Avatar
Vette9c6
Default So....
If I parked my car with front wheels turned so it looks sexy and shut it off. It stayed this way overnight. I started it up with out turning them straight after a little bit on idle the service active handling came on. I shut it off straightened wheel out and started the car several more times with no issue. Is the code because the car sensed the wheel not being straight to the original start up position when it calibrated what is supposed to be straight?
Old Mar 16, 2019 | 10:35 PM
FAUEE's Avatar
FAUEE
No. The car doesnt care if you turn it on with the wheels turned.
Old Mar 16, 2019 | 10:40 PM
Vette9c6's Avatar
Vette9c6
Wonder why it happened
Old Mar 16, 2019 | 10:54 PM
Vette9c6's Avatar
Vette9c6
Would a low tire cause it? I did have a low tire and when I pumped it up it cleared that code and the lo e tire code?
Old Mar 16, 2019 | 11:15 PM
FAUEE's Avatar
FAUEE
Low battery could. Lots of other reasons. Steering position sensor, yaw sensor, lots of stuff rolls into that system.
The dealer can pull codes for what caused it I believe.
Old Mar 17, 2019 | 10:52 AM
jrose7004's Avatar
jrose7004
Just one of those things, but I don't think it caused the message.
To So....
