Door damaged/cracked from mechanic/paint shop
Gave my 08 C6 in to a shop to fix the right panel after I hit a pothole. The right panel had bent upwards and I didn’t notice, so when I opened the passenger side door it rubbed against the panel and created a small but noticeable crack.
Gave my car to a shop to fix, and noticed the door was cracked when I got it back. From this, the passenger side door doesn’t not open at all most of the time with the electronic door handle. Before all of this, the door had no problem in opening. Anyone have a similar experience and what can I do?
The way they painted it was very poor as well.
Pictures of before and after the crack resulted are attached.
Received 4,820 Likes
I would be contacting your body shop asap
Did you contact the shop and discuss the problem with them?
I did take it back to the shop, they denied doing it even after I showed them a picture I took of the car just a couple weeks earlier. The picture clearly showed there was no crack near the door handle prior to giving the car to them. I even showed them how the paint was not smooth on the panel and they said thats how they do it...
Not sure what else to do.
^^Did you pay with credit card? Id dispute it and get the BBB involved and let the body shop know you will be doing that. It sounds like they are going to keep denying it.
Received 1,834 Likes
Holy crap bro small world. I just called a body shop today to have this EXACT repair done to my 08Z. My car came with this on the door and I want to get around to fixing it. Unfortunately they said I will have to repaint the whole door and then possibly blend into rear quarter panel. $600-1000 job... Sigh. Let me know what you end up doing with yours. Not sure on when I am gonna have this repair done because I dont wanna spend that money right now. But will def have it done at some point this summer.
Here is a pic of mine, way worse than your's. Our cracks are literally reversed mine is a black Z with white cracks and yours is a white vette with black cracks lol.
That's crazy! I did let the body shop know about the damages and they denied doing any of it. After some back and forth they refunded my $400 for the initial fix. I sent it in to get a crack fixed and got it back with worse cracks on the door handle and the passenger side door handle doesn't work most of the time. I watched videos on electronic door handles and it's mostly from debris build up, but for my car it was perfectly fine before I gave it to the body shop.
Looks horrible, wondering HTH those cracks even got there & that bad.
Given it's black $1K probably isn't all that bad considering they want to do entire door & blend some back.
One hellova lot of work, there.
Anything less than perfect they'd have to deal w/ you, and you wouldn't be happy.
Brake ducts & surrounds are chewed to hell on my '08 w/ 62K. If not for Apsis I'd be doubly screwed.
IF anyone I could trust quoted me 1 large to repaint just those 2 areas I'd be one happy camper.
Might be no more than door took one hellova hit only cracking paint, must be some story behind that.
Paint flexes some w/ our composite bodies but if hit hard enough it cracks.
I've small spider cracks on front facia and never 'hit' anything except rocks kicked-up sometime in the past.
The stuff cracks.
IF lucky it's only paint, remove paint/refinish and it's as good as new.
Providing, shop knows what they're doing.
Make a sign up that says "Example of repairs done by ____________(Fill in the body shop name). Not a happy customer". Tape it to the door and draw an arrow pointing to the shoddy / incompetent work. Take a picture and go back to them and tell them you don't mind giving them free advertising by example. You could also park your vette in front of their shop with the sign on and see what happens.
B. If you threaten someone with a false claim, with the expectation that they will compensate you, your are breaking the law.
Other than that, it's a great idea....
