How to freshen up LS2 with 50k
Hey guys, was on a trip from Nashville to Atlanta over the weekend, and noticed that after the 4/5 hours of driving, the car seemed a little sluggish on acceleration, and the idle seemed to dip down to 350/400 very briefly after pushing the clutch in during stop and go traffic. My car is just shy of 50,000 miles, and it makes me wonder what I can do to refresh some of the bits and pieces that might be getting lethargic after 12 years. Any help or advice would be greatly appreciated.
blower
sonik_fury (04-02-2019)
At 50k your engine is barely broken in. Run some techron or other fuel cleaner in it, change the air filter, and rev it out a good bit. Sounds like you may have some carbon build uo or something.
Make sure and clean the throttle body. If it has carbon buildup, it will cause some minor problems. Plugs, coil packs ok?
I’ll have to grab some Techron and run it through. I’ve got a K&N filter that hasn’t been cleaned in at least 8k miles, so I’m sure that needs some love. I’ll have to check the throttle body and intake. I would assume the coil pack and plugs are fine at 50k, but it wouldn’t hurt to give them a once over and replace the plugs since they are cheap.
The plugs don't need replacing, plugs in these cars are good for 100,000 miles just like GM says.. Replacing before that is a waste of time and money...WW
owc6 (03-31-2019)
I personally have never cleaned it, no idea if the PO had. I was under the impression that they needed to be cleaned and re-oiled every so often, is that wrong?
they do need to be cleaned and re oiled periodically but the oil can be a problem. DON'T overdo it with the oil or it can get on the mass airflow sensor and mess it up. It would be a good idea to clean the MAF when you do the air filter.
seijack (04-07-2019)
50,000 miles is nothing..
Not really sure what you are asking.
Cheers.
jimijam (04-01-2019)
Received 2,683 Likes
2018 C6 of Year Finalist
^ For once he’s right though. Supercharge it.
Like I said in the post, I was just curious what items in the driveline, or fluids, or odds and ends, could be replaced after 12 years. I know 50k is lower mileage, but I also know that some things can deteriorate with age. Just curious as to what might help breathe some new life into it. Just looking to prolong the life of my car with simple maintenance, and looking for others who have similar mileage, on a similar year, to see what experiences they have had.
Cheers.
Cheers.
Landru (04-01-2019)
I would kind of agree with 50K miles, what can be defined as "freshened up" ?
There is the time passing factor to consider and OP states car feels sluggish.
Here's my .02 cents
1) Drain & Refill Transmission and Differential fluids.
2) Replace Spark Plugs and wires...test coils.
3) Inspect Harmonic Balancer and serpentine belt for alignment
4) Add a can of Techron Concentrate and run tank to empty, then change motor oil.
5) Inspect and clean the Throttle Body blade.
6) Inspect and replace your intake air filters,
That's the easy stuff.
If still a drivability issue, I look to the Fuel Injection System.
7) Inspect the wiring to the injectors
8) Check for an intake leak
9) Best for performance remove the injectors and have them professional cleaned with their spray adjusted.
Lastly, is the clutch starting to slip at 50K miles?
You could go deeper, but again my .02 as for a suggestion.
I probably spent $600 of your money with my check list above.
Good luck!
Here's my .02 cents
Good luck!
