side marker leds
Old Apr 2, 2019 | 06:30 PM
yellow2007's Avatar
yellow2007
Default side marker leds
Installed these this past weekend and they are incredibly bright compared to stock. Makes the car so much more visible.
after
after
Old Apr 2, 2019 | 06:44 PM
EVRose's Avatar
EVRose
Very nice! I've had those for several years and love them!
Old Apr 2, 2019 | 06:53 PM
FAUEE's Avatar
FAUEE
Are those the oracles with the single line of LEDs? They look to diffuse the light a lot better than other pictures I've seen of them.
Old Apr 2, 2019 | 07:19 PM
yellow2007's Avatar
yellow2007
Yep..They are oracle. I kept them clear so they do diffuse better than painted. but still have that "line led" look.
Old Apr 3, 2019 | 07:57 AM
enventr's Avatar
enventr
It looks great! I was thinking to do the oracles as well!
Old Apr 3, 2019 | 07:08 PM
yellow2007's Avatar
yellow2007
I love that they are so bright, I can be seen better at night. They will paint them for you and even do a "ghost" led but it's an additional 2 bills. If you go unpainted like I did, you do have to clear coat them first. Install was easier than putting on socks
Old Apr 3, 2019 | 07:21 PM
SB64's Avatar
SB64
Where did you get them?
Old Apr 3, 2019 | 07:52 PM
jimijam's Avatar
jimijam
tell us exactly which ones you got that are listed on the below website, and why did you have to clear coat them? it states on their website that clear is required IF you diy paint them yourself, which you did not do.
https://www.oraclelights.com/product...md-sidemarkers
also, your pics to not look like just a thin line of leds lights up, but the entire marker light does. is that they way the look in person?
Old Apr 4, 2019 | 12:25 AM
myredhead1's Avatar
myredhead1
They look great!
Old Apr 4, 2019 | 08:02 AM
cadyshac's Avatar
cadyshac
If you don't want them painted can't you just add a LED bulb to your existing marker light and achieve the same thing?
Old Apr 7, 2019 | 09:14 AM
yellow2007's Avatar
yellow2007
Oracle
Old Apr 7, 2019 | 09:20 AM
yellow2007's Avatar
yellow2007
The picture doesn't do it justice. They are indeed just a straight line of leds but the clear makes it look diffused.There is only one style for the C6. They need to either be cleared which I have now done because of the plastic lens. It is a softer plastic than OEM. I may at some point do a black ghost to it so they match the spoiler, front splitter and flag emblem inserts.
Old Apr 7, 2019 | 09:22 AM
yellow2007's Avatar
yellow2007
These aren't led bulbs. They are a strip of leds that lights the entire length of the lens not just where the bulb is. In person it is not diffused like my pic.
Old Apr 7, 2019 | 09:26 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
The Oracle lights are a LED strip. I pulled out my side marker lights and replaced the bulb with a LED and all you get is a very bright spot. Went back to the OE bulb.
Old Apr 7, 2019 | 09:59 AM
yellow2007's Avatar
yellow2007
Here is a very close up shot of the leds.....If you paint the lens this will be all you see.
Old Apr 7, 2019 | 04:36 PM
CorvetteSparky's Avatar
CorvetteSparky
Same here. I wasn't happy with the single LED in place of the incandescent bulb.
Old Apr 13, 2019 | 07:48 PM
yellow2007's Avatar
yellow2007
Painted them this weekend.
To side marker leds
Old Apr 14, 2019 | 04:10 PM
Mike Green9's Avatar
Mike Green9
Were they a simple plug'n'play - unplug stock markers and plug in new led strip?
Thanks,
M...
Old Apr 14, 2019 | 05:35 PM
yellow2007's Avatar
yellow2007
Plug and play......Waiting for the paint to dry took longer than installing them....
Old Apr 14, 2019 | 08:07 PM
KevDude's Avatar
KevDude
That looks amazing, although they are pricey.
